Kenmore 110 not filling. Seems to be timer push pull switch. Anyone had success fixing it?
Zoey
Member
Jul 20, 2025
24
Kenmore 110.22642100. Sometimes nothing happens when I pull the switch, sometimes it'll fill for a second then stop. If I pull the timer knob out hard and keep holding it, it usually keeps filling. That's also the only time the continuity tests good.
Continuity of pressure switch, water valve, water temp switch and water level switch all test good. Pressure switch test where you blow into the hose also tested good.
I just put in a used transmission and now a few loads later this happened.
    1.6 MB
I’ve had a problem with my Whirlpool Mark 18 where it would randomly stop when filling (this happened on various cycles), would push the knob back in and pull it back out and would continue to fill as intended. Looked into it, timer contacts weren’t really pitted. Turns out, the master switch would pop out ever so slightly stopping it on the fill portion. Removed the timer, added a couple drops of oil and lubricated the cam assembly and was back in business. Not an issue since then, works as intended.
Thank you everyone! I removed the knob and sprayed some Deoxit in around the stem and in around the little black plastic piece and it's working now. 🤞
I have another variant of this timer that I'll open up to see how it works in case this one stops working and I want to try and fix it.
    2.3 MB
Yay, Zoey, glad a little lubricant made it work. Never hurts to do something like that.
Hi Dan, thanks for posting the cool video, but I think that pretty much proves the point that these are not made to fix however I have fixed things more difficult than that that we’re not designed to fix either.
Most of these white plastic timers that we see that have failed have usually burned up where the connection block plugs onto the timer and they’re usually in pretty bad shape other than that they were actually pretty reliable.
If you’re gonna try to fix them, you probably should have a spare timer because of course you can’t buy any parts for them from the manufacturer at least.
John L
Probably a bad timer, doesn’t make any difference if you try filling it on hot water?
If the timer on your washer is white plastic body, it is not really repairable look for another timer.
John L
Why not? (I'm not experienced with those) If there are snaps or screws holding it together, it seems you could access cams and contacts like any other one, if you're careful...
Thanks again for everyone's help. I took the cover off of an identical-looking timer with a different part number to see if I could understand how randomly spraying Deoxit into the center of the circular discs helped.
Pulling the knob drops the grey bar, allowing the protrusions on the rotating discs to activate the switches. Did spraying into the hole in the center of the rotating discs somehow free up the grey bar? Or did the spray somehow manage to reach the leaf contacts? Some youtube commenters say that if the contacts are worn, dirty or burnt, any fix won't last.
If I know what did it, I might have a better idea of whether it's just a temporary fix and if I should start looking for a new timer.
Thanks!
    1.8 MB
    1.2 MB
I have a 110 model and initially had a tub leak water got in the transmission over time leaking from outer tub seal thru the main seal that was worn and then the main spring broke from corrosion from water ingestion over time again .The transmission would lock up and not spin.Fixed the tub seal and transmission then the timer had issues replaced the timer on E-Bay ($40) Works like new again so I had three issues.I would replace your timer easist job to do shop around on E-bay dont buy from parts online they are $150 if not more Good Luck GP
