stopmeister72
My neighbor across the street had this out on the curb. The impeller had stripped so got a new pump today. Putting this in place of my Kenmore Elite Ultra Wash which does well but needs a grinder and is now leaking rinse aid. pain in the butt to get the pump in, very tight quarters. Enjoy the pics. Nothing prerinsed. The measuring cups have solid candy melts in them and alot of it. The Asko needs a new upper washarm suporrt hub. When the upper rack is in the lower position, water comes out the top inlet port so not enough pressure to the arm. Work ok in the top position. Guess there is a bad or missing rubber check valve flapper. Will see it did tomorrow. Also went into the program mode and set it to super rinse which adds two more rinses. Anyone else have an Asko?
http://https//partners.asko.se/fts/...&jezik=en&tipVsebine=1&docName=8090977-en.pdf
