That machine does have the D.A. agitator. As far as speeds- it will depend on the number of cycles that machine offers. I use to own a similar model (all white) back in the early 90's til about 05. My machine had a 4x3 group of cycle keys not the 3x3 that this machine has. Can't tell which cycles this one doesn't have that mine did. Agitation speeds I would figure possibly three...my machine had four (reg, med, low, int. low) along with three spin speeds (determined by the cycle you used).
The dispensers do flush out with water. The detergent dispenser can handle both liquid or dry depending on what your using. Detergents got dispensed into the tub as soon as the wash portion of the cycle started. Presoak and prewash (if you set these options, machine could advance into wash) you add into the tub and load dispenser for the beginning of the wash cycle. Bleach got dispensed during the last four min. of the wash, fabric softener got dispensed once the washer filled and started agitating during the rinse cycle. Occasionally you would have to take out the dispenser parts and wash them even though the machine rinsed out the dispensers during there appropriate times.
The one feature I really miss about that machine is that you could delay start the washer for up to 9 hours. The presoak could be set for 99 min. So essentially you could fool the machine by filling the washer and let it start with what you wanted to soak. Once the machine started, you would turn the machine off and reset it to presoak for 99min. then advance it into it's whatever cycle you wanted and finish and load the dispensers accordingly and tell the machine to delay for up to 9 hours. Overnight soaking made easy...set it up...go to bed that night...wake up the following morning to the washer being finished.
Plus all the options...Presoak, prewash, 2nd rinse, or wrinkle guard could be added to whatever cycle you wanted to. And the machine adjusted the speeds accordingly.
http://
