Kenmore Portable Washer Shakes Excessively
pumpkina
Sep 2, 2017
100
California
during the spin cycle.
It looks like the photo below (note that there are NO links in this post).
What should I look for when working on it?
Also, these models weigh about 225 lbs, much more than full size. Why do they weigh so much?
Thanks!
I guess with my bionic arm, I forget how much these weight as I have two of them, and lift them myself in and out of the Jeep taking them to events for show and tell...
Walmart is showing these machines from 1.0 cuft capacity at 43lbs...and the 1.7 at upwards of 77lbs....
also, if you don't add a link, an icon wont show up to check for one....
Thats not even the same model in the above pic. The one in the link is a completely different animal altogether. The one in the above pic is agitator based and the link one is impeller based. The washer in the Whirlpool version is LCE4332P and weighs a whopping 85 lbs and with water filled to High and clothes...max weight is 260 lbs total.
The above washer uses a rod and spring suspension system and it could be that one of the rods is out of the holder in one of the 4 corners. There are 4 rods in this washer. This washer is also called a "World Washer" since more than likely it had its birthplace in Brazil. Its also belt driven.
Model
Brand: Whirlpool
SKU: LCE4332PQ
UPC: 050946962948
Stock Id: 21494
Product Number: WPLCE4332PQ
Appearance
Color: White
Type: Top Load
Capacity: 2.1 cu. ft.
Control Type: Touchpad
Technical Details
Energy Star: Yes
Portable: No
ADA Compliant: No
Reversible Door: No
Location of Controls: Rear
Type of Controls: Touchpad
Bleach Dispenser: Yes
Stainless Steel Drum: Yes
Fabric Softener Dispenser: Yes
Self Cleaning Lint Filter: No
Soak Setting: No
Number of Cycles: 4
CEE Rating: Not Available
Weight: 85.00 lbs
Dimensions
Width: 22 5/16"
Height: 38 1/4"
Depth: 24.625"
Details
Volts: 120 Volts
Amps: 15A
Stackable: No
Features
Temperature Settings: 3
Usage: Residential
Steam Cycle: No
Water Heater: No
Wash Cycles: 4
Leveling Legs: Yes
Connect With Us
This info I found online.
connect with us?....Mike, your so helpful, your one in a million, well, at least in this galaxy....
don't we all have to be on the same planet to connect?
those interstellar data rates are killer!
I wasn't clear: I haven't yet seen it in person. This evening, I'll look at it and post the model and serial number.
Thanks for your help thus far!
Wait a minute....you mean to say this is not your machine and that it belongs to someone else?! Your opening post suggested without saying that it was in your home, you owned it, and you were asking for advice to a problem YOU were having with said washer. Sometimes being a tad clearer might help.
Kenmore Washer 44722
Model Number
110.44722400
Serial Number
CRR4306120
Despite being level and having balanced loads, washer vibrates a lot during spin cycle. What should I look for to fix this?
Thanks
Check the parts diagrams at SearsPartsDirect.com.
Could be bad suspension rods, or broken/missing suspension straps.
There are foud, one in each corner...
Simply unscrew the two HEX screws on the back of the control panel and lift it...
Disconnect the wiring harness plug and the pressure switch hose.
To replace the suspension rods, just lift the tub a little bit, grab the rod and spin it until it releases from the sleeve.
It's a lot easier if you replace one at a time. In 10 minutes tyou can replace them all and reassemble the top. it's very, very easy.
PS. wear gloves.
I removed the top and found that all four washer suspension straps (#22 in the diagram below) were missing. I think that a new suspension strap will connect to the inside wire of the washer suspension rod (#23, below).
However, there's no bolt hole for the suspension strap to attach to the basket. It looks like they connected the suspension strap to the basket with Zip Ties. How do I connect the suspension strap to the basket?
Also, what are common causes of all 4 suspension straps breaking?
http://www.searspartsdirect.com/par...oryName=Residential Washers&brandName=KENMORE
thanks
Thanks
thomasortega referenced the motor counterweight: "Also check if the motor counterweight is on it's place.... if it falls, the motor weigh causes an unbalance."
How do I check the motor and the drum counterweight?
