Kenmore Six Hundred in Northern Virginia
I had never seen one of those
Great find, can't wait to see it operate. Congrats Jeff, it looks like new inside, can we also get a closer picture of the control panel?
Thanks!
What an awesome find! It is beautiful!
The motor is enormous! Does it have a HP rating?
Congratulations! You will have a blast with this one!
Big DW Motor
The motor is a fairly standard [ for the time period ] 1/3 HP, it does look big in the picture. Impeller DWs almost always had a 1/3 HP motor that ran at 1725 RPMs. Better DWs that had a pump usally used a 1/3 HP motor that ran at 3450 RPMs, I think that KA was probably the only company to use a motor rated at 1/2 HP, they used a 1/2 HP motor on the 15-22 series DWs.
Thanks for the information John.
That motor looks huge!
Looks like a very fun machine!
Brent
Motor shot
Note the insulation in between the double walls of the tub and cabinet. Unlike the single wall GE, the wash chamber is pale pink porcelain, not Plastisol. Next to the motor, note the rubber sump for the drain pump. That is one place where you can run into serious trouble if the rubber gets hard and cracks; not as much trouble as with using a rubber carried in a wallet for a couple of years that degrades before use, but none-the-less, a situation where liquids are not contained.
