Kenmore Top Loader?
Kinked Bleach Hose
That's not the correct hose, take it off the BD and see if you can cut it shorter and reattach without the kink.
To test the BDer take the hose off and pour hot water in it and attach a 120 volt line cord and see if the wax motor gets warm to the touch and allows water to flow through in about a minute or two.
John L.
I believe that is the wrong outer tub for that bleach dispenser assembly. On the machines that had the automatic bleach dispenser that was built into the tub ring the hose was installed lower on the side of the tub and because yours has the hole in the tub for the common gravity dispenser it has caused the kinked hose. As recommended you may be able to shorten the hose to make it work.
Outer tub
Most likely yes. I was told that the original outer tub was causing some issues with spin, so it was swapped out with an outer tub from an 80 series. Other than the cutout for the bleach dispenser, were the size dimensions of the outer tub the same from the 80 series?
The seller of the machine said he was getting a lot of wobble and then swapped out the outer plastic tub. Once he did, he said the issue was resolved. That's what he told me.
Yes, I recall you said that previously, but I'm not figuring *how* the outer tub can cause that effect.  It's essentially a container to hold the water.  It oscillates *with* the basket during spin but is not itself a moving part.
The guy who refurbished my machine believes the piece that comes with the clutch (I'm not sure what it's called) has more play in it than it should. I thinks it had come off and was resulting in the clicking noise. We have since applied grease to the brake rollers and spring. The tub doesn't come to a complete stop like it did before, but it's very quit now.
That is the brake cam.  The clutch band latches into it and turns it when spin starts to spring-release the brake shoes from contact with the brake drum, and drive the basket.  The cam mounts to the bottom of the spin tube/brake assembly, anchored with a c-clip.  Did the clip pop off?
