I've been using the A-9 all week. My theory about not clearing out the chute after grinding proved correct, and there is no spewing now. However, the grind it produces on the FINE setting still has some larger chunks in it. The brew hasn't been as flavorful as that from the KCM grinder and I've been playing around with the amount of ground beans. I've been getting my beans from the same independent coffee roaster for over 35 years and they aren't cheap, but my morning coffee is important enough to me that I'm willing to pay a premium for it. I only make two mugs' worth each morning. That said, I don't want to waste beans on a grinder that can't render the fine grind required for a cone filter.
This morning I decided to try the blooming/wetting method that the '70s era Chemex Automated machines use, which is to start the brewing for long enough to saturate the grinds, then shut down for a minute or two. Doing this helps to extract the most flavor from the grind. With my Bonavita machine, this requires a manual process, so I stop the brewing process after about 30 seconds, shut down the machine, wait a minute or so, then start it up again. It made a big improvement and I just might be able to continue using the A-9.
When I used this same blooming method on the fine grind from the KCM mill, it seemed to overbrew so I stopped doing it. It's no big deal for me to start using this process again.
In addition to the look of the A-9, I really like that it's quiet, and that it's fast. Right away the cat learned the sound of the much louder KCM grinder and could hear it from her sleeping spot in the back yard, even with the windows closed. She'd be at the back door demanding breakfast before I could start brewing my own coffee. So this quieter grinder will let me get away with enjoying my coffee, newspaper and breakfast totally under her radar. We'll see how it goes. I'm not ready to give up on the A-9 just yet.
