Best US DW available at the moment
jamiel
Jan 29, 2005
2,695
Detroit, Michigan & Palm Springs, CA
Pshaw. Bad week with the dishwasher down and both cars laid up....anyway.
Have had a 100 series (plastic bottom) Bosch 2 rack for the last 12 or so years in Detroit. Been quite happy with it. White front control....cheap and cheerful
Returned from vacation to an E01 error. This tracks back to either heater or control board fault with pump. Disinclined to have a likely $200 fix on a $650 dishwasher.
Also will likely re-do the kitchen in the next couple years (celebrating our 20th year in the house). Not sure what the decor will be (alas).
Inclined toward another cheap white Bosch unless anyone has a good alternative. They have de-contented them pretty drastically (no longer a time display on the front panel--only 3 LEDs (>2h, <1-2>h, <1h). Consumer Reports still likes them, but NY Times Wirecutter claims they're not what they used to be and is recommending Miele or Maytag. Don't want to pre-suppose what our decor will be by choosing black or stainless (which opens up more options).
We put an 800 series Bosch in with the 3rd rack in Palm Springs...I don't like it any better than the 12 year old cheapo one....
The 100 series is available from Lowes with 2 day delivery--anything more ambitious (Maytag/KA) has a longer lead time.
Combined with both cars being in the shop (keeping me from visiting the stores) I'm struggling with ideas. Would love nothing more than just to sling one in the back of the station wagon and be done with it...
Best available dishwashers would definitely be the high-end KitchenAid and any Maytag dishwasher. I would definitely get one with the self cleaning power filter so you don’t have the messy filter that has to be removed and cleaned occasionally.
There have been several reviews over the last two years here on this site where people got these dishwasher not only do they hold a lot more dishes, but they do an outstanding job Eugene in Cleveland got one Mike electric country got one that he loves in Michigan and several other folks my partner, Jason just bought one about six months ago and loves it so far.
If you’re gonna go for a cheap dishwasher, I wouldn’t get an expensive Bosch, in fact, I would get the cheap whirlpool or Amana if you’re just trying to buy time, or of course, why don’t you just fix the one you have for a few years if you’re planning to do a kitchen remodel.
John L
The current 100 series should be pretty similar to your old 100 series one.
I personally wouldn't get one with the plastic bottom tub.
Those once were known to have issues with becoming leaky - but that apparently hasn't really been the case recently. They probably all have pump issues sooner than that.
Going higher gives better noise performance mainly.
Unless you go really high end and get a CrystalDry model - that gives you another level of drying performance.
However at lower price points, I don't see why a Maytag wouldn't suit the situation either.
The new Whirlpool wash system has been quite good for most people as well.
Not quite as efficient, but nothing horrendous either (unless you talk 1h cycle - the usage of the WP 1h cycle is just stupid...).
Honestly, a MOL Whirlpool or BOL KitchenAid would be great for most. The design with removable filter is more reliable and still does great. If you wan TOL, the KA machines with microclean filter have been decent. Though a large number of people will be hard pressed to find differences other than 3rd rack. We love ours and it has never skipped a beat, but does have very small little rust spots I’m not thrilled about.
I'd just get another 100 (ascenta) and call it a day.. Ours is 6 or so years old now but I did have that pinhole leak in the sump hose whenever it drained. I bought the part and fixed it myself. That was a bit disappointing to have happen. No one else I know with a Bosch has had it happen. my luck. Don't know why people bitch on the plastic bottom, it's never been of concern to me. why would it?
Whenever other alternatives exist most Europeans consider anything plastic inferior, cheap and tacky. Be it dishwasher tubs, Tupperware containers or God forbid plastic tumblers (yuck).
Plastic attracts oils and soil and can emit nasties like plasticizers whereas stainless steel and glass are considered clean.
We`ve had plastic interior dish washers too but they vanished from the marked in the 1970s. The cost cutting plastic bottoms we see now again is a step back not everyone is happy to see.
Call it cultural differences. LOL
Search Facebook Marketplace for a used Whirlpool/Kenmore Ultrawash with a Powerclean module. Cheaper alternative, better washing performance.
The plastic bottom BSH DWs were introduced some time in the early 2000s I think.
Back then, those DWs easily lasted 10+ years. However, a not to small number of the plastic bottom machines developed leaks around the joint between the stainless steel upper half and the plastic bottom of the machine.
There were first party repair kits for those situations - but they were quite a bit of work, didn't have a 100% success rate and often failed again relatively soon. Add to that only entry level machines had those designs, and repairs of that fault just weren't really feasible.
Given that the rest of the machine often was pretty much in pristine condition when the joint seal failed, ot just wasn't easy to recommend the BOL machines.
Now, the expected life of the wash pumps is something in the range of 8-12 years probably, depending on usage, care, generation, etc.
So you might run into that seal issue - but the likelihood of it actually becoming a problem is smaller.
Funny enough, there was a short window of time where the fully stainless machines had sealing issues between the tub and the sump.
There is a repair kit for that issue as well - with pretty much the same issues as the repair kit for the plastic bottom machines.
Nowadays, if you just want a BSH DW that lasts as long as possible and you are somewhat handy yourself, getting one without CrystalDry/Zeolite and a full stainless tub is the go to.
The wash pump over here is something like 90-110€, the repair can be done in less than an hour from built in to built in again and requires not much more than a simple screw driver.
From my experience with both the low-end Bosch here (condensation dry, 2 racks, plastic bottom) and the 800 series out in Palm Springs (Crystal Dry, 3 racks, full stainless) I find:
--easier to find dishwashers now than in the middle of COVID. Had to settle for higher-end than I necessarily wanted to get delivery in a reasonable time
--investing in the Crystal Dry in a desert climate was silly...if I don't have a problem with condensation drying in Michigan, I'd never have an issue with 5% humidity :)
--wish I had option of the water softener with the hard water in Palm Springs
--I've got several specific items which fit precisely in the 2 rack which I am very skeptical would fit easily in a 3 rack (which eliminates Costco as a vendor--they only sell 3 rack). Likewise there are several things out in Palm Springs which fall over that would fit with ease in Detroit.
--seen on one website or another....I'm an architect loading the dishwasher---Brian's an artist.
--not having mobility is a PAIN in the ASS at a moment like this (should have at least one car back tomorrow). Had reserved a car Saturday at a local AVIS and they called to say "sorry, no cars" as their inventory isn't instantaneous
As my grandmother would say....oh swearwords.
It seems there was a day when most categories of appliances had a ‘hands down this is the best’ brand. With so many corporate mergers, new options from foreign markets, and government regulations, things have changed up the market a lot. I’ve installed Bosch, Miele, and KitchenAid in different houses and been happy with all. Currently I have a KitchenAid with the deep third rack and have been amazed at how much it holds. A real plus if space is a need. 8 years of near daily use and no problems as of yet.
Nope---believe that it is only in the highest level (Masterpiece?) .
Not to confuse matters, but popped into the local high-end showroom which I recalled having some floor models around....they definitely do---found a new in crate 2022 300 series Ascenta (i.e plastic bottom) for $375...only problem is that it's black. They also had an Asko in stainless for $500.....we're gonna head over there tomorrow with plates/skillets to see what fits.
