KitchenAid KDC-17A pulled from The Pile
redcarpetdrew
Apr 12, 2008
3,751
Fairfield, CA
Saw this in the haulaway pile today. Nice, clean little machine. Put it thru the paces. Other than the broken handle (try finding THAT) so far I cannot locate why it was destined to die.
Say 'AAAAHHHHH'...
The racks are in excellent shape as is the gasket. No R/A dispenser although I'm sure it could have been an add-on like the Maytags were with a kit.
The wash arm. Sounds just like a Kitchenaid by Hobart. I still love the description "Hurricane In A Box". This one sounds like it could remove the flower pattern right off the dish! The underside is as clean as a whistle - no leaks or leak marks. The blower motor for the heating assy is stiff, so I will lube that. Nice Machine...
RCD
another great 17 model kitchenaid
i picked up one of those from a guy here in cinti last year for 50 bucks. he bought a new dishwasher and could not believe that it took over an hour and a half to do a load when his kdc-17 would do it in a half hour. he said if it weren't for his wife he would have kept the kdc. he was a restaurant manager and was big on hobart!
it might not have the bells and whistles like the superbas but it still is a great dishwasher! i put a new motor on mine even tho the old one worked fine. this was before i found any superba 17's and i thought the custom model might be all i would ever get. little did i know then that superbas were to start popping up all over the place!
anyway, it looks great, better shape than the one i have, looks like it had an easy life which is good for you!
enjoy it!
Drew your the pide piper of machines this year nice finds.
So nice for you to share your wares to the people hear thanks.
Hobart machines rules.
Darren k.
Thanks Rollermatic -
I have this model in coppertone in my kitchen , Although it came with the house & I`m afraid to use it it does display well.
My wringer sat dormant in a barn for 2-3 decades before I got her and she fired up perfect. I think you might be surprised. Take the lower panels off and watch for leaks and try it out! Besides, that's what breakers are for... LOL!
RCD
Thanks Andrew -
It never ocurred to me to leave the bottom panel off while the machine is running,
Several years ago while I was cleaning the controls , The machine quickly came to life , Scared the hell outa me.
I know it wants to run .
My goodness man!! Turn it on with the bottom panel off, flashlight in hand, and see what happens. Maybe nothing but pure running without a problem.
What I'd do first is pour a pot of hot water in the tub and check for leaks before running her. This will also help the seals after sitting for a while. If there are no leaks, run the drain to make sure it will drain and the drain lines to the sink are in good order. After all that, THEN you run a rinse cycle. If all that flies, Turn it loose!
RCD
