Kitchenaid KDI-21A Pump Top Kit (242638)
ptranswasher
Feb 16, 2022
4
Atlanta
Hi all,
New to the forum, though I did buy the KD-21 service manuals from here last year.
I've been refurbishing our 1986 KDI-21A, and I pulled the pump assembly above the disposer to install a new (pn 116003) rubber boot for the upper spray arm.
When I removed assembly 242638, I noticed a crack in the lower body part, the piece that holds the bushing for the lower spray arm. Before I marine epoxy the part, I thought I should check here first to see if someone has a 21 that is being parted out.
The rest of the machine is really clean, and in great shape, it was washing great before I decided to work through sprucing it up.
Hey Steve!!
<span style="font-family: helvetica;">You sold me mine for my KDS21 about a thousand years ago it seems.  Actually it was about nine years ago.  What a difference it made!  This is what my old one looked like.</span>
[this post was last edited: 2/18/2022-07:49]
Stevet,
This assembly contains all the parts I would like to replace. So yes, I would definitely like to purchase it from you. I will send you an email to your profile email.
-Phil
Chachp,
That is one of the parts in the assembly, but not the one that was broken (see photos below of the repair I started to make).
Thanks very much for the link, I bought that part and a couple others for a rainy day.
Sounds like it will work out with Steve.
<span style="font-family: helvetica;">You won't go wrong with his advice.  He has bailed me, and others, out many times over the years.  On his advice, I did a marine epoxy patch job for my 15 series machine while I was waiting to find a replacement.  I eventually found one NIB on eBay but this one worked fine while I waited..</span>
Stevet,
Do I need to reach you a different way than the profile email? Please let me know when you have a minute, if you didn't receive my about the ASSY in this thread.
