short story - pump died after 1.5 years, self cleaning filter self destructed, extended warranty replaced it.
long version -
a couple months ago in a kitchen not so far away, started it one morning, came back was off. Started again, left for awhile - sanitized light blinking. No water in tub, but could tell it hasn't finished cycle - things were still dirty.
Started a cycle, drain pump would start but then get an error saying drain pump was bad.
If you put water in the tub and then start, it would pump the water out and and continue the cycle adding water and then just sit. (the drain pump is not bad) Bought the Home Depot extended warranty and after getting someone to come out, said at first the water valve was bad, then did some more checking and said the motor was dead. He left the old one so finally tore it apart to see what the deal was. Looks like the screen on the self cleaning filter tore itself up jamming it up. Will see how long the new one lasts. Weird thing, is why give a drain pump error with the main pump was the issue???
Overall the dishwasher cleans pretty well but the next one will be a Bosch.
John
long version -
John
