Hello all,
I own a Kitchen Aid KDS-17. The original fill valve has begun leaking and will not flow sufficient water to wash the dishes. So… time for a new valve. The original valve assembly is a Dole N-42. I found two replacement options at RepairClinic.com:
Part number DW-42, which looks identical to the N-42 double coil valve.
-or-
Part number 4171000, which is a single coil valve.
Have any of you had any experience with either of these valve assemblies and if so, is one better than the other?
Thanks for your help!
-or-
