KitchenAid KDS-18 Front Panels
Comes out the front from where?  Visual identification is the best way to troubleshoot water leak issues.  Remove the lower panel for a look-see.
Cancel/Drain rapidly advances the timer to the last drain period (after the final rinse, before dry commences), then rapid-advances again through the dry period to Off.  It may stop the rapid-advance at one increment before Off and finish to Off at normal speed.
No drain no gain
Hi there. I shop vac the water out of the tub. For some reason it will not drain. Everything else works. It sprays and cleans amazing! Just when it comes time to drain it does nothing. I’ll grab pics tomorrow!
