KitchenAid KUDM220t1 Loud Rumbling noise
Motor data plate information: model number: S62NXHRJ 7199; part 242892
Does the symptom indicate that it is likely the motor has gone bad? If so, is there any source of supply for the motor or motor repair?
My KitchenAid dishwasher (KitchenAid Kudm220t1) has a constant and loud rumbling noise during all motor operating cycles; wash, rinse, and drain. This began a week ago. It may sound similar to a layer of small gravel in a metal can as the can turns.
I’ve taken the interior down to the metal drain impeller. This drain impeller is still installed. Although I tried to see if the drain impeller could easily be removed like the wash impeller; it could not be easily removed.
The metal drain impeller spins freely when turned by hand; no noise. Same with the wash impeller.
I was hoping to see debris in any of the breakdown but everything is clear and clean.
Could there be something under the drain impeller causing the noise?
If the drain impeller is removed does the shaft to motor seal stay in place? I want to avoid creating a dishwasher leak.
There are no leaks showing under the dishwasher or on the motor that are visible.
Thanks
Thanks
