dough77494
Both drums of my 1986 Maytag LA 506 are removed and require cleaning, rust remediation, and repair of a pin hole in the outer drum adjacent to the boot seal mounting flange. The seal surface of the agitator stem is rusted and also in need of restoration to ensure the new mounting stem seal is not quickly damaged. Have read several posts on the topic of cleaning / removing soap scum and heavier residue accumulation and understand acid base cleaning agents are not for use on porcelain. As both drums and the agitator shaft are no longer available - further damage by cleaning must be avoided.
What cleaning products are recommended for removing heaving detergent accumulation? After a several minutes of using a plastic scrapper on heavy accumulation the edge was blunted to the point of no longer being useful. A friend mentioned using a Scotch Brite pad and WD-40.
Was planning to use a rust converter and cold galvanizing spray on the rusted areas - upon reading the rust converter application instructions they advised to not use a zinc based material as a following top coat, suggesting an oil based paint.
Have considered use of FlexSeal on the bottom of the outer tub - not clear if that material is suitable for exposure to detergent and bleach. FlexSeal's application instructions recommend the surface be scuffed / roughed up prior application - not clear this is a good idea for use on porcelain. The extent of the spotty surface rusting is such that the entire interior bottom surface of the outer tub should be coated.
Use of JB Weld was recommended in a posting on this forum for patching small holes - not clear what JB Weld product is preferred for this application - their RTV silicone or classic epoxy. My concern is that whichever material is applied to the inside of the outer tub that it never come loose to plug the tub drain, drain hose, or the pump.
Regarding the agitator shaft seal area - had considered use of a shrink sleeve, although have not researched to determine availability. As suggested in another post in this forum, removing the agitator shaft is strongly not recommended, which precludes machining the seal area. What is recommended to reliably repair the shaft's seal area?
I need to complete all repairs and return the machine to service ASAP as I do not have a backup.
Thank you for your recommendations and comments.
Doug
Doug
