I picked up this washer last year from someone local, and I just hooked it up recently. The first few washes seemed fair enough.... I had to clean the water inlet valve, clean out the pump, and had to clean the valve and solenoid for the detergent dispenser. It is pretty quiet and seemingly smooth. NOW the issue? See videos: Now when I wash, the agitator won't always spin. I give it a little movement and it will usually start up strong, OR if I stop and restart or stop and change the keys to a different wash.
Is this an issue with the transmission? Or maybe as simple as the WigWag assembly? I hate to go through all the work of pulling the transmission just to have it be something simple.
Visually, I don't see anything wrong.
I thank you!
I thank you!
