Questions
Diomede,
The dial with the numbers is the program selector, it's for whites, colors, delicates, wool etc.
Michael,
No, you can't do a tumble rinse with the tap open and the drain on. This is a fully automatic machine. However it does fill - drain - fill - drain at the end of the main wash and in the first rinse. It does it in very short bursts, about 10 - 12 times I believe. It uses a lot of water to rinse!
This load was 5 very thick bath towels and a somewhat smaller towel.
Greg,
This machine is completely automatic so you spin the clothes after the last rinse. I guess you could use the softener button to let it stop before the last rinse and give them an extra spin before the softener rinse.
Yes, the water flows in the dispenser from the back. You can see the fill spout at the top left in the picture in post #254296. The larger opening left from the axis is the other fill spout which is used when the dispenser doesn't need to be flushed.
Gabriele,
These machines are a smaller variation on the H-axis twintubs that were so popular in the Netherlands. But some people didn't have the space for them so these smaller machines were designed. They can be put under a table and a separate spindryer can be put away somewhere else.
Louis
