Late St Nicholas delivery: Constructa CA 801
foraloysius
Silver Member
May 21, 2001
12,852
Leeuwarden, Friesland, the Netherlands
Today my St Nicholas gift was delivered. It's a compact H-axis toploader. It washes and it rinses automatically, but it doesn't spin, so you need a separate spindryer. This machine is from the 70's. It has three controls and a button for a rinse hold so you can add softener for the last rinse.
Louis, that's my first washing machine! Well, it was Siemens branded but for the rest it looks identical. I bought it new in 1981.
Theo,
I was actually looking for the Siemens version but Santa decided this one was good enough. I love this machine, the softener rinse button always intrigued me. But there are more interesting sides on this machine like the rinse - drain - rinse - drain etc. at the end of the main wash and in the first rinse. Never saw something like it on other cycles than permanent press.
BTW, you must come over for a wash-in sometime in the new year.
Darryl,
I'm actually not sure about the capacity, most of these machines could hold 5 kg, so 11 lbs. But I don't have any documentation about this machine, but my guess is it is the same or just a bit less, 4.5 kg.
Louis
E bravo GIGI!
Louis, I'm happy for you that Santa let you find under Christmas tree I think our best preferred WM... it's a TLHA though!!!!
I know how much you love them (as I do either!!) so HAPPY CHRISTMAS WASH!
Is the mumbered knob for soaking time? In Seventies here it was very common: you set the prewash and the machine let it last thi time selected then it stepw forward on doing the main wash...Candy, Indesit, Ignis i.e. had it!
What about a pic of the drum oponed?
BYE
Diomede
Mike,
The softener button stops the machine at the drain increment of the third of four rinses. You drain the detergent compartment by removing the red plug. Then you put in the softener and press the softener button. The machine continues and adds the softener to the last rinse. The detergent compartment is not totally flat so it will hold the softener until it's flushed.
It's beautiful, Loius
Amazing the way stainless steel seems to have found the fountain of youth
Can you do a tumble rinse with it, drain open, water on
Cool machine! Very interesting the fact that the drum can be removed so easly! Strange that it doesn't spin, but as you said the machine will last longer, plus since you have an extractor it shouldn't be a problem! Indeed cool! Complimenti :D
Questions
Diomede,
The dial with the numbers is the program selector, it's for whites, colors, delicates, wool etc.
Michael,
No, you can't do a tumble rinse with the tap open and the drain on. This is a fully automatic machine. However it does fill - drain - fill - drain at the end of the main wash and in the first rinse. It does it in very short bursts, about 10 - 12 times I believe. It uses a lot of water to rinse!
This load was 5 very thick bath towels and a somewhat smaller towel.
Greg,
This machine is completely automatic so you spin the clothes after the last rinse. I guess you could use the softener button to let it stop before the last rinse and give them an extra spin before the softener rinse.
Yes, the water flows in the dispenser from the back. You can see the fill spout at the top left in the picture in post #254296. The larger opening left from the axis is the other fill spout which is used when the dispenser doesn't need to be flushed.
Gabriele,
These machines are a smaller variation on the H-axis twintubs that were so popular in the Netherlands. But some people didn't have the space for them so these smaller machines were designed. They can be put under a table and a separate spindryer can be put away somewhere else.
Louis
Nice machine thanks for sharing
It looks like the tub lid comes completely off for loading and unloading? Does the machine automatically stop with the tub door at the 12 o'clock position or do you have to manuver that there?
The Stabers were a real pain in the A&* for that! You always had to try to flop the tub of wet clothes to the 12 o'clock load position by hand and would always scrape your knuckles!!
What would happen if you forgot to lock the door in and started the cycle? Is there an interlock to prevent the machine from running without the tub door?
jet
Thank you Jon,
No, this machine doesn't automaticcaly with the opening at te top. You have to turn it manually upward, but it's no problem, the outside of the drum is not sharp, at least I haven't yet scraped anything.
Yes, the tub lid comes completely off. If you hang it on the outer lid handle you won't forget to put it back. And no, there is nothing to prevent to start the machine without that lid on the tub.
It's a very basic machine, probably the reason why there are still a lot of these machines around.
Louis
Oh Louis I'm so glad St. Nicholas found your name on the "NICE" list, rather than the "naughty" list! What a lovely gift for him to bring!
Does Santa normally come to Groningen on Christmas day (Dec 25) or Little Christmas (Jan 06)?
~Why doesn't the machine spin?
This avoids the need for a suspension and simplifies construction. It also cuts manufacturing costs and therefore sales price. As mentioned abouve it keep the machine working and like-new for a very long time!
Think: twin-tub washer.
