Laundry Question -- Black clothes.
hooverwheelaway
Jul 24, 2005
1,490
For my job, I have to follow dress code:
Black or white shirt, black pants.
It's wonderfully simple.. But I've been irritated because my black clothes seem to fade -- and they fade at different rates. So if I want to wear a black shirt and black pants, sometimes they're two different shades of black.
I've tried using less detergent, washing in cold water, only washing the black items together... blah, blah, blah.
I know that some of it probably has to do with the quality of the material from which the clothes are made. I have some nicer things, and I have some not so nice things.
Nonetheless, Robert and I are about to head to the Mall of America, and I'm going to buy some new pants and maybe a new shirt. I'm hoping that I'll be able to get rid of some of the badly faded things, and sort-of start fresh...
I was told by a co-worker that if I soak things in vinegar before I wash them for the first time that the vinegar will set the color. Is this true? Has anyone had experience with this? I am also curious about some of the detergents that are on the market specifically for black clothes.
**Discuss**
LOL
Seriously though.. Any advice would be greatly appreciated!
Oh yes, soaking in vinegar is a must and not only for black clothes. The soaking makes the fibres "get used to the washing process". Not only will colors fade less (no fading at all is hard to achieve) but it will also make the fibres shrink less.
Besides soaking in vinegar you should wash your black clothes separately in a detergent especially for black clothes. Or if that isn't available use a detergent especially for colors. Make sure there are no optical brighteners in the detergent you are using.
Happy shopping and happy washing!
Louis
Here is what I do.....
I always wash any new dark clothing in a vinegar wash the very first time. Strong vinegar. I rarely wash in cold...for anything, new or not. So typically I will use the Filter Flo, warm wash, usually a small load, and a cup of white vinegar. I just run them on a full cycle, but a really short wash...like 3 mins.
As for regular washing, I only use a detergent specifically for darks on any dark loads, or at least one with no OBA's. Cheer for Darks, Woolite Dark, etc. I really think that makes a huge difference. I always wash on warm in the Filter Flo, and dark clothes get a 105 degree wash in the Miele. I think good rinsing is key, as well.
So, that is my 2 cents. Good Luck!
What we do for black
First thing is to turn inside out the black clothes (we do all our clothes this way) the for black or dark colors we soak in vinegar and salt in cood water. Have used Cheer for darks but like the best Woolite for Darks. Wash in cold water and rinse. Also we hang dry in the house these then when dry just run on touchup in the dryer to remove any wrinkles. In our front load put in vinegar in the bleach depqrtment every time to help hold the color.
Maybe it's the water...
Ever see a fence that was bleached from the chlorine in the water that is sprayed by the sprinkler sytem? This will do the same to clothing. You may want to look into some water filtration sytems for the house or the washer.
Jim
I never heard of soaking in vinegar, but I have heard of and done a salt soak. Seems to work. I think Westie2 hit on the best answer, turn them inside out. I always do this with my black jeans and such and it really works. Also, if I want stuff to really keep it's new look I NEVER put it in the dryer.
I have 3 pairs of jean styled Dockers that have never seen the dryer and the look like new after over a year of use. Hang them on a hanger from the waist and let them dry in the basement, then just a light pressing and they are looking good.
Ive had good luck with my darks using Cheer and Cheer for Darks. Never powder like Tide or Foca. I also keep the agitation times short, always less than ten minutes for lightly soiled t-shirts and jeans.
Yeah, it's the chlorine in the water. It fades colors like crazy. Filtering out the chlorine will be good for both you and your clothing.
We wash with
rain water so no chlorine in our supply still our colors fade too! Soaking in vinegar (and using it instead of fabric softner) helps to stop fading! Saltsoaking does work too but I have no idea why as some company ever said that you can wash with salt...? I use vinegar... washing insideout is a must and using a detergent for colors or black clothing. I've heard that drying in a dryer fade colors too... so I hang dry them in the shadow...
Our Navy Blue School uniforms were always directed to soaked in a Salt bath before washing. Was supposed to be one cup of salt to a bucket of water.
Never too much additional fading, they were line dried and we'd grow out of them before they faded too far.
Fading...
Ohh sorry to hear that Fred.....her`s what to do...
Machine Selection: Asko
Programme: Easy Care High water level
Detergent: Woolite Black + tablespoon salt - no conditioner
Drying:after spin shake out & hang to dry
Strong detergents will cause fading, fab con will add a coating & optical bloom which can dull or add a grey shading, often heat in a dryer will make it worse!!!
Go on be harsh - make the man get the asko out!!!......... Ouchhh............what was that Slapppp for!!!!
dry cleaning and cotton fabrics
I ve read that perc can damage cotton fabrics, indeed many labels say "don't dry clean". Is that true ? Why ?
T.I.A.
Carlo
The most important thing that goes unnoticed!
Dry on low only, detergents starts the process, but over heating and over drying will continue to ruin the finish.
I have a pair of black pants that are no longer jet black but they are still black after 6 years of delicate washing in cold/dry on low.
I will post a picture later when I get home from work.
Favorit: my beloved father owns a laundry, dry cleaning and traditional. Everything, for 20 years, except my underwear got washed in perc and I have yet to see stuff fading ;) even jeans often get washed in the big ILSA machine!
It's true that solvents will strip colour from the textiles but thay do so only if they're not temperature controlled. So stay assured that dry cleaning a delicate garment will preserve it better than water washing it!
~Also, if I want stuff to really keep it's new look I NEVER put it in the dryer.
Failing that, use medium or low heat in the dryer. Heat fades color, even in the dryer.
IIRC you basement is unheated, so one must use a TIMED dry or a SENSOR AUTOMATIC DRY in order not to over-dry, which may also contribute to fading. TIME-TEMP AUTO DRY may take a VERY long time to shut off the machine in an unheated environment. (If it shuts it off at all. You see, the timer only advances when the heat is OFF).
When using vinegar one does not want to use a washer with procelain guts. It will eat the finish.
There is always RIT dye to reblacken blacks, if you can dedicate a machine to that function. But then you really do have to make sure the dye run-off subsequently does not get on to anything else.
[oh lawd please help me resist the urge to make a King of Pop joke!]
Toodle-ooh
Salt or vinegar
both work as mordants. The linked article is basic but explains enough about the process.
I hadn't thought about the chlorine in the water, but, obviously, that would contribute to the fading. Hmm, a separate chlorine filter just for the H/C washer lines? Shouldn't be too expensive.
Dryer heat definitely plays a role as does too hot of a steam iron.
Learned a lot here, thanks all!
Does anybody know if any of the PERC alternatives have proved truly useful? It's already 2010 and we only have about another 10 years or so in many countries before PERC is banned for dry-cleaning.
http://en.wikipedia.org/wiki/Mordant
Vinegar
Good points!
I'll add my little tip. I use 1/4 cup vinegar rather than fabric softener in my final rinse. Definitely slows fading, and helps with residue and lint in this day and age of "self-cleaning" (read none) lint filters.
We were once told by Rick Ralston (the guy who founded Crazy Shirts in Hawaii) that hot dryers are the major cause of color fading. We asked if line drying is better and he said not by much, because UV rays from the sun also fade colors. He told us tumble drying on low heat, with garments turned inside out is the best way to minimize fading.
detergents for darks...
Sorry I have to say that but detergents for darks do no better job on darks than a good color-detergent. It is just a marketing gag by the manufacturers and that had been proven by German consumer reports. I will put the link the the report at the end of the post. Unfortunately, it is written in German, maybe someone can translate (panthera maybe? ;-)
So many people as well say, "I only use liquid for colors or darks because of white spots or stripes on dark laundry". Well, I had white stripes on dark jeans many years ago when my mother washed my them but since I figured some stuff out that I did not know before I have no problems with fading colors. I also refuse to soak my new clothes in vinegar even if that works well. I just don't like that.
Here is how I do my darks:
- I never mix darks with something else.
- I turn everything inside out
- I chose my Miele Navitronics "darks" cycle
- I use a good detergent for colored items (I use Ariel Color&Style or dm "color" or Persil Megaperls Color)
I haven't heard about the fact that much heat in the dryer makes the colors fade but since I do not dry darks on max heat, thats no problem for me.
I suggest to people whos washer do not have a darks cycle to select the delicates cycle and to raise the water level to maximum.
Here the promised link. I know it is from 2001 but I don't think that anything has changed.
http://www.test.de/themen/haus-garten/meldung/-Waschmittel-fuer-Dunkles/20185/20185/
Ummm....
many scrambled sentences and the sense gets lost here and there. It is okay to get a basic impression of the text but I would prefer a more detailed translation. I eventually can do that, when I have more time.
i have never done it, by i have had nurse friends dye a nursing uniform White to cover totally unremoveable stains. A bottle of black rit may save the pants. alr2903
Larry, that's a most unusual personal pic you've chosen. Have you ever studied the development of the guillotine? It's a fascinating story.
stupid me....
I did forget to say that I rarely tumble dry my clothes. Dryers are hell on fabrics, and do tend to fade faster. I guess that was an important fact I forgot to mention in my first post. :)
