hotpoint95622
Put the last few connections on and then hooked up the water and drain hose fixed the front back on refitted the door seal and plug in the power.
I was not expecting much but the door lock light came on and the water valves started and filled to the original water level this machine had, valves shut off and then the MOTOR started, tumbled for 12 seconds stopped for 6 seconds and then restarted anti clockwise for 12 seconds. It repeated for 12 wash actions and then the HEATER came on BLOODY HELL, motor for 6 seconds with 12 second pause and the glass started to get warm, continued till the 40c stat kicked in. Back to 12 second wash with 6 second pause for the duration of wash then pump and distribute. Program ended there so will have go back to computer to find out why it did not go onto rinses.
Can’t believe it went at all.
And no water on the floor, no RCD tripping.
