lg dishwashers
gelaundry4ever
Nov 18, 2014
4,276
Temple, Texas, USA
Hello everybody. When did lg first start manufacturing dishwashers? When did we start seeing them in the states? Why do these dishwashers sound weak? Why do the pumps turn on and off when they start the wash action? Why is there no high temp wash and heated dry option? I'd like to know. Thanks. P.S. I have read consumer complaints that say that they take forever and don't clean.
I have no idea about the history of their dishwashers so i can't comment on that. But after reading the manual on their base model, most of their cycles the standard wash temp is what "heated wash" would be on other brands. My Frigidaire, for example heats the water to a minimum of 120 degrees if heated wash is NOT selected and 140 degrees if it is. LG recommends a minimum of 120 degrees from the hot water supply. Apparently they just heat the water anyway...except on a couple of the shorter cycles. I attached a cycle chart.
As far as the pumps turing on and off, from my experience it's probably from either using a smaller size motor and the pause allows it to cool, and the fact that most new dishwashers use less water so there probably isn't enough water to run both upper and lower sprays arms together and be effective. That's how my Frigidaire works too. However, it cleans beautifully. I rarely have a problem with leftover soil.
Mine does have a heated dry but a lot of the newer models do not..they have extended drying...which LG does too, to save energy. I have no idea how that works.
From the reviews I read, most were positive. There will be negative reviews on ANY product. So make sure you read all of them and not just the ones that say what you want them to say. People are dumb and I find these reviews useless in most cases.
I can't speak for the LG
But my Kitchenaid dishwasher (Whirlpool sourced) has frequent stops when the wash is first beginning, and then a few times during the wash cycle. this is when it is sensing the soil level and temp.   This may be why the LG makes frequents stops, but I am just guessing.
One thing you will see online.
You will read more complaints, as people are more likely to complain about something, than praise it.
Many of the complaints are user error.  The newer machines are not as powerful and are certainly not your Mother's  Hurricane in a box.
You have to be careful not to nest bowls so the water can get to all surfaces.
Make sure the water is hot by purging the lines so the machine has a good start.
Use a good quality, and ample detergent for the soil level.
Choose an appropriate cycle for the soil level.
Here is an example, though I am not saying I am always right; this is just an example of varied results.
My aunt, God love her, has the exact model and make machine that I have.  This is where the simularities end.
I use a good quality detergent usually either Cascade Platinum, or Finish Quantum vs She usually buys the cheapest, sometimes outdated product on the shelves.
I do not Prewash vs.  She washes the dishes in the sink then places the clean dishes in the dishwasher.
I choose either the normal or heavy cycle, which are sensor cycles,  and choose a heated option and/or heated wash or sani rinse vs She uses the shortest cycle (Light soil), which would be appropriate with her prewashing except. . she never chooses any options.
I use care in loading so that the water is able to reach all surfaces vs She piles dishes upon themselves to save having to run more loads.
I use Finish Jet Dry vs  She does not.
Results:
I rarely take a dish out of the machine that is not spotless vs.  She always complains that the dishes are dirty with redeposits in the glasses, spotty and she has to dry them by hand.
She would complain and blame the machine online.  I would not as I see the problem as user error.
I have read/heard consumer complaints...
There is a serious issue with basing all your experience of anything based on reviews you have read on the Internet. You just don't get a clear picture of what is really going on out there.
It is human nature to write negative reviews when a person perceives there is a problem, but it is comparatively less common to write a glowing review for something that works well. Yes I realize that positive reviews exist, I'm only saying that there is a disproportionate percentage slanted towards the negative.
Secondly when reading such reviews, both positive and negative, we have near zero idea what the writers experience is. Perhaps the problems are user induced (see also the "stinky washer" syndrome). Any washer is likely awesome if it is the first one a person has ever used etc.
Without knowing the percentages of machines that are out there working just fine for people, you have no idea how much weight those negative reviews deserve.
We read reviews all the time about some of the early front load machines and how horrible they are. How does one explain users here in this group that has had them for 10-15 years and they love them? Clearly the reviews don't tell the whole story.
Had the Internet existed in the past, you can bet that machines back then would have had negative reviews too. People experiencing problems with things and complaining about it is hardly a new concept. The Internet just makes is WAY easier to see it all.
Machines today are built lighter and with more plastic and electronics. It is possible that their life spans will be reduced as a result. It is far more likely that they will be judged as "flimsy or poorly built" just based on a persons perceived ideals. Electronics are the same way, folks are scared of them because they don't understand them. In today's cost cut world, I'd wager that the mechanical timers made today would be expensive and not as long lived as vintage ones also. Plus you loose the wonderful advantages that electronics can bring. In the end the concept of designing the "perfect" machine that will last forever is ludicrous. It could never sell due to cost and the average consumer is going to replace the appliance far sooner then need be replaced anyhow.
I think new dishwashers are better
Just my opinion but they are one appliance that I think has improved greatly over the years. Granted if I could find a nice condition KA dishwasher of the Hobart design from the 80's or early 90's (in black), I'd snatch it up in a heartbeat, but for the most part I'm very very happy with new dishwashers. Yes loading it correctly is crucial, even in the best machine. It can't clean where the water doesn't hit...that's just common sense.
I remember tons and tons of times as a kid emptying the dishwasher and throwing uncleaned items in the sink to be reloaded and washed again. I hardly ever have to do that now. But of course my dishwasher loading skills have improved with age too lol.
Biggest thing I like is noise level. I had a GE or Hotpoint Potscrubber type machine in a previous apartment about 5 years ago. That thing was LOUD. Holy crap, it would wake the dead. I thought it was broken when I moved in and was excited that maybe I would get a new one. But the maintenance guy called me and said it was fine...and it was. LOL.
In the new vs old arguments I don't think there is any appliance that has degraded more then the dishwasher. If my machine died I wouldn't buy a new machine to replace it...
In a move to try to make dishwashers silent, they just don't move any water anymore. They also use slightly less water then before but I'm not sure this is really the reason that modern ones may not perform like their ancestors. I have installed two new Whirlpool dishwashers in the past couple years, I remain amazingly unimpressed with either.
Dishwashers today do have the advantage of modern high performance enzyme detergents which helps them to a degree.
poor quality
LG dishwashers are poor quality! They don't clean dishes at all! There is no high temp wash or heated dry! Rinse aid is required! The electronics and motors fail! LG should be ashamed of themselves! It doesn't matter how you load them! They are caked with film and dirty food particles that are baked on! I'm glad my dad has a whirlpool gold dishwasher that is miles better than that Korean piece of crap LG! I have read tons of reviews and I am glad I have saved myself some grief from LG's lousy garbage! The whirlpool my dad has gets right down to business! LG's are just dishwetters! What a piece of crap! They are the worst I have ever seen!
Seriously.
And after I explained why they don't have a "heated" wash, because their machines heat the water anyway!! It took me like 3 seconds to copy and paste that chart. 3 seconds I could have spent doing something else. OMG. :-/
Look, it's not that we're trying not to be kind or helpful.
It's that when we ARE kind and helpful with explanations, sources and facts, they're thrown back in our face with hyperbole, claptrap and misinformation, over and over and OVER and OVER again, and with the same stupid, non-quantifiable youtube clips.
Don't feed the troll!
I do not believe he is a troll
If you can't find tollerance, then either skip the post or block the user.
We could try to use our knowledge to mentor.
[this post was last edited: 10/30/2015-10:29]
weak pump
Why is lg, Samsung and everybody else putting weak pumps in their dishwashers? If a dishwasher is quiet, it doesn't clean! How are lg dishwashers supposed to dry your dishes without heated dry? You can't! It doesn't matter if you used rinse aid! You can't put a huge load of dishes up to capacity in these dishwashers! The racks are too close to the jets! They should be called dishwetters! Lg's take for years and years to get your dishes clean! LG needs to learn from GE, Whirlpool, Maytag and Kitchenaid and Frigidaire from the past! Quiet equals dirty dishes! If my dishwasher is loud due to intense spray, that means it is doing what is supposed to do! Dishwashers are supposed to wash your dishes! Who said that Samsung and especially LG were allowed to make appliances, including dishwashers? Nobody!
http://https//www.consumeraffairs.com/homeowners/lg-dishwasher.html?page=4
I have had 6 dishwashers.
I have had 6 of them! They had powerful, not wimpy pumps like dishwashers are supposed to! I don't do drugs! Period! I do my research! I read consumer reviews! I'd rather have a hurricane in a box that is heavy duty, not a cheap, flimsy, Chinese and/or Korean piece of crap power lawn sprinklers! They're delicate machines! They're power lawn sprinklers! No way am I getting a brand new Chinese made dishwasher! Assembled in the US doesn't made in the US! Parts are from China, Korea or Mexico! No offense, but that's what the fine print says! Ask Spatsbear!
I'd love to, but.....
when I block the user, HALF of the AW forums in the community dissapear now.
This place has single-handedly gone to $hit.
