washerdude
I've been using the LG WM4370HKA for a couple weeks now. I like it for the most part. I think the rinse is truly reminiscent of Maytag Neptunes with the drum turning and making the water flow through the outer tub to clear out the suds. But one thing does bug me a little, the turbowash sprayers located on the 4 and 8-o-clock position don't spray at full intensity like they do on the rinse cycle when the machine is in the main wash phase. They seem to start up, spray at a good intensity then reduce pressure and you can hear air passing through the re-circulation pump and don't spray nearly as hard at all and sometimes barely touch the clothes. Who else experiences this with their LG when they select turbowash on the normal cycle? I've seen videos of the WM3770 and WM3570 performing and they never seem to experience a pressure drop with the spray nozzles during the main wash on the normal cycle.
