lg/kenmore front load washer extremely heavy
gelaundry4ever
Nov 18, 2014
4,595
Temple, Texas, USA
Hello everybody,
I have noticed that my Kenmore/LG front load washer is EXTREMELY heavy. What is inside the washer that is extremely heavy? It's even heavier than the matching dryer, but even more so than the matching GE set I had. Is this machine full of concrete? It does a great job with its accela-wash (same as turbo-wash) feature, and when I put it in test mode, I set it to the bleach dispenser/active rinse mode and I heard how powerful the active rinse/atomizing rinse nozzle was. Very powerful at full water pressure. I had two laundry pairs prior to this one at my dad's, and this Kenmore Elite has to be the heaviest I've ever seen. Same as my mom's lg tromm. I'm sure the accela-wash has a more powerful pump, but the weight of this machine is like comparing a semi to a pickup.
What are your thoughts?
Jerome
balancing system and 6motion/smart motion
What does the lg tromm/Kenmore elite front load washer's suspension have? What does it consist of? Did lg update the motor/drive system or is it still the same?
How many counterweights does the lg front loader have?
direct drive motor and pump
How big is the direct drive motor? Did they upgrade the drive motor? How powerful is the pump? How many gallons per minute does it circulate and drain? This is especially true if the accela-wash/turbo-wash is active.
LG FL'ers weigh from 202-210 pounds. My WP duet weighed at 245 pounds with the newer ones being 2 pounds less.
The motor I don't think is heavy at all as well as the pump. I think majority of the weight comes from the balancing counter weights. My Maytag Neptune MAH5500BWW is the same weight as my WP duet was, however sometimes when the machine starts spinning, the ENTIRE machine shifts, something my WP duet almost never did.
pump flo rate and main pancake motor
What is the flow rate of the lg washer pump during circulation and drain? I've been looking for the flow rate but couldn't find any info on the flow rate. Did lg upgrade the pancake motor for the 6 motion? Surely they should be able to handle tough loads.
If you're SO concerned about the flow rate of a circulation pump, why don't you pull it out of the machine, put it in a 5gal bucket, and time how long it takes to drain the bucket.
Do the math. You'll have your flow rate.
Only LG engineering and the motor vendor will know the flow rate.
It's inconsequential to the customer.
HEAVY?......you don't know what heavy is!.....
until you see 4 guys trying to lift a Westinghouse slant front into a pickup....
even something like a Kenmore Belt Drive has some weight to it compared to their Direct Drive cousin....don't care how out of balance it goes, its not walking from its spot...
plus I don't know of any dryer that needed counter balance weights....
thundering vibration during spin
I noticed my machine does a thundering vibration noise during high-speed spin you can hear across the house. This is true for the normal/casual, heavy-duty and whitest whites cycles, all of which I use the accelawash option.
It's important to make sure all four feet are firmly planted. On the washer, not the owner. Make sure the top of the machine is level, and that you cannot rock the machine side to side and front to back, or even diagonally.
My Neptune 7500 is essentially the same machine mechanically as the 5500, and it has never tried to walk on me. However I have noticed that the floor under it is not the same as the floor in front of it. It will rock when I pull it out of the laundry closet, but it's fine once it's back where it belongs.
Hey, it's and old house, and this is quake country.
level machine
My machine is level. FYI, have you noticed that the normal cycle is labeled different names on certain models? It still does normal tumble and high speed spin. Mine has normal/casual cycle which is the regular cottons cycle while the workout wear is a permanent press cycle which I rarely ever use.
