pierreandreply4
from what i am seeing i think that your washer as the atc function and it might affect the heating performance or your washer is hot and cold fill and what cycle do you use normaly? normal/casual gentle or have you tough that it might be a defect in your washer.
what i would suggest you try is
1 start your washer with no clothes the temp you use for a normal load and let it run a full cycle after the heating part of your cycle i would suggest you stop and open your washer door and check the water tempature with a termomiter if it reads your reg temp then its not your washer water heater or it might be that the washer as a sensor that check if fabric can stand hot water as sometime the washer might send cold water to cool down the heated water to preven damage of fabric.
