LGWM3900 Washer Rec. Settings & Water Level
@Jbrady
Rinse levels are right at the drum lip (post-hack).
However, depending on cycle and load size, sometimes the rinse water will rise up the glass door. Most I’ve ever observed is probably 3” high or so.
Normal cycle rinse will pass drum lip at times and so will Speed Wash, and same for some of the specialty cycles on the app which I rarely use. I believe it was the Juice Stains cycle where I saw the highest rinse level ever.
Bedding and Towels have a very consistent water level for both washes and rinses so I use those and Normal most often.
