murando531
I was wondering that as well, about the baffle. It seems it would generate a bit of a "whirlpool" (pun most CERTAINLY intended) that would keep soils loosely held, and I think the pulsing of the drain pump when draining while the wash pump still runs helps too. I've yet to pull that filter out to find any more than a speck or two, which will be gone by the next load. I could probably never take that thing out the entire time I own it, and it still wouldn't need manual cleaning.
I still have concerns about those bottle jets running with the upper arm on the GEs. If there is an upper constant rinse arm, the four bottle jets which seem to have decent sized holes, AND the upper rack wash arm that is X shaped with all four blades spraying, and water having to fill ALL of that tubing and the arms and have enough volume to generate pressure from the holes...it just seems like a lot going on all at once. I guess I'm surprised that they didn't do what WP did with the silverware spray or KitchenAid with their bottle jets, and just dedicate a diverter valve port just to that zone.
I wonder, if water powered only that upper rack arm alone, would the end jet have enough power to get the peanut butter glasses clean?
