I have installed several LED lights in my camping trailer. I noticed one significant problem with the white LED's that is never discussed. The phosphor in them degrades after about 2000-4000 hours. Yes, the LED still lights up, so the manufacturer can claim that the LED still works, and has a 100,000 hour life span, but the brightness is significantly reduced.
Still, I used the LED's in my camping trailer for low-level night lighting. They use minimal battery power (around 120 millamperes at 12 volts, or about .1 watt) Their overall brightness though is rather weak. They produce the light of about 3-4 little 3-watt "peanut" bulbs. Obviously, that's much more efficient, but it still isn't enough light to perform major tasks like preparing a meal, or reading by. For that, I installed some 12 volt CFL lamps that use about 13 watts, and produce the same amount of light as a 75 watt incandescant.
LED lights have a long ways to go until they can produce the same brightness per watt levels as flourescent bulbs, especially many of the newer CFL's. There's also the reliability issue. I have seen numerous LED traffic signals around town with groups of LED's burned out in them!
MattL, if you do not like the color of CFL lamps, there are several varieties avaliable with different color temperatures. I know the Lowe's here sells "warm white" which looks like an incandescant, "day light" which is a real white light like sunlight (and probably more like your halogens), and there's "cool white" which is a sort of bluish light. I also recommend getting good quality CFL's...pay a little more, and get a good quality bulb. The cheapie ones don't have solid state ballast, so they flicker, and they have cheap, poor quality phosphors, which is probably the reason why you are annoyed by the color quality.
