dustin92
Today I decided to investigate why our Maytag Performa (Norgetag) gas dryer is taking so darn long to dry, because it has normally been taking 80-90 minutes to dry a normal load, also it seemed pretty noisy and almost sounded as if it was rumbling a bit. I figured out how to open the top, then the front. Not too difficult. I took the front panel off and the air duct that runs down the front of the dryer to the blower was filled with lint... level with the bottom of the blower housing! I removed that (a large handful), then removed the duct from the front panel, and vacuumed it all out. Then cleaned inside the cabinet as far as I could reach. There was a decent sized clump of lint laying right behind the burner. While I had it apart, I cleaned up the drum where it rides on the seals and slides (one of the felt dampers had slid from under the slide. I put it back in place and reassembled everything, again, not too difficult. It ran much quieter with the tons of lint removed and the slides cleaned. It seems to dry a bit faster as well. We are lucky that a fire didn't start with all the built up lint.
