Oh Wow, great pictures Steve, gosh that is a beautiful machine. The clutch on this machine was used from 1956 thru 1960 or so. My first Automagic had the same clutch issues, you see the clutch pads have a tendency to wear in this style clutch and after a while you will not get a good spin pick up or full spin speed. So I took the clutch apart and repadded the clutch shoes, that improved the spin pickup from 2.5 minutes to slightly over 1 minute. When I got my 2nd '59 Philco, the machine had very little use and the clutch was still performing at about 1.25 minutes to bring the tub up to full speed. It is not difficult to re-pad the clutch shoes in this style clutch, but before I describe the process to you, how does this machine prevent the tub from turning during agitation? Can you rotate the tub in either direction or does the tub lock when you turn it in the opposite direction of spin?
