Look VERY closely at the drum.... What's wrong with it?
pulsator
Bronze Member
Jun 30, 2002
2,377
Saint Joseph, MI
Found this video on Youtube of the previous generation Whirlpool Duet washers. Look at the drum very closely, you only get a couple of glimpses but, WOW! Did they have a new drum in the prototypes and then decide to not use it? I wish they had! It looks very pretty!!
<object width="960" height="745"><param name="movie" value=""></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="960" height="745"></embed></object>
Well, whirlpool may have finally got it right. I took a look at these the other day when I was at Lowes. The drum is no longer tilted. There are jets in the baffles. However, I have been told that the hot water setting is only between 80-95 degrees.
Nice, but none of the Duets has this drum - not even the three new ones (94, 95 and 97HEX). And the control panel says "Clean Washer with Bleach Only", rather than "... with Affresh".
Hot water at 80-95°F? :O That's cooler than I wash my dark delicates! How are stains supposed to go away without pre-treating? Does the machine have an extended wash period?
