Look what Youcrate brought me today!!!!!!!
Here's the tub, which has issues, but it's unique being the very first perforated V-12 tub, and similar to the one on the first "V" model I ever saw, so I'm going to try to save it:
with any luck I'll be able to replace it with this one swiped off of a discarded machine 40 some odd years newer. Funny how this size tub was first rated as having a 12 lb. capacity, then 14, then 16, then GE just gave up and called it "standard capacity".
But the jewel in the crown is the dial: no, not illuminated as this machine is one step away from being a BOL (which is one reason I love it), but a color that, I believe, was used once, and only for this particular model. Welch would have shot these people. Course, I'd like to shoot Welch, but that's not in the spirit of this thread...
Sweet
That is a cute GE. Good luck with the repairs. It is funny on the water level switch instead of "hi - med - lo," they use pounds. (Like you were supposed to keep a scale next to the washer.)
And the biggest switch is the SUDS-SAVER switch-- I love it
So happy for your and so grateful to Robert.
Bet you've thought of this: just snip off the inch of trunk with the leak, and slide'er right back under the clamp.
For a near BOL, GE sure knows how to put on a good show.
I do like the Blue, for sure.
Now if it only came on the dispensall. But since you have such a good progressive attitude ("Welch would have shot these people. Course, I'd like to shoot Welch"), I'm not going to argue with you about about which might be considered the PRID-DEE-IST.
The Minnesota - Connecticut Express
Yay Ken congratulations. Did it just arrive, they picked it up a few weeks ago? I was actually wondering today if you got the '61 OK. I was thrilled to be able to see a '61 in action and even more thrilled that its gone to a home where it can truly be appreciated. Yay again.
Congrats on your new washer! I'm sure you'll love it. I remember seeing this beauty when I was at Robert's wash-in, very cool.
ooo this is VERY cool. The hole pattern looks more uniform than the random pattern that I've seen on later wash tubs - hopefully you can save it.
Love that blue dial and filter pan.
The SUDS, the SUDS!
Ben
The motor-pump "linkage" thingie isn't looking too good.
YAY! Congrats. I just love when machines are exchanged/moved within the club! Generosity and kindness rules!
Here is to dreams coming true (Champagne glasses clink!)
Thanks to all, as usual.
"Did it just arrive?"
The shippers were incredibly accommodating; because it was July 4th weekend and they had to bring it to me in a smaller truck, they were able to schedule delivery later, even though it came to the Wallingford depot in only a couple of days.
"The motor-pump "linkage" thingie isn't looking too good."
Yeah, the leather straps are looking worn, but they're incredibly durable.
All I really have to do is change three of the drain/suds return hoses and put in the new washbasket although I am trying to preserve the old one. I'm having a little difficulty finding the right adapters to put on the old main drain hose leg which is custom-fitted to this machine and has a flare at the pump end. Just needs some more leg work. Someone recommended that I go and get some bilge-pump hoses made out of lighter and more flexible plastic. I'll definitely post pics as I finish the job. This is the very first suds-saving washer I've ever seen, less owned, and I'm dying to give it a trial run even if it means storing the water in a plastic garbage can.
