Looking for info on new refrigerator/freezer
retro-man
Aug 23, 2007
1,645
- boston,ma
My sister lives in Williamsburg,VA and is looking to replacing her units. She currently has a Northland fridge and Northland freezer. Dimensions are 36" wide and 84" tall. This includes the condenser and compressors on the top. They are about 8-10 years old and giving her constant issues. The repair guy is like a member of the family, just walk right in and go to work on them. I am attaching a few pics of them. The freezer is to the left and fridge is to the right. Any info about what is out there currently and reliability would be most appreciated.
Thanks
Jon
Have to get to work, but did a quick perusal of built-in brands that scored well in Consumer Reports' tests: Thermador, Miele, LG, Bosch, a specific model by Liebherr (the least expensive at $5200), certain SubZero models. Expensive! Nearly all but the aformentioned Liebherr range in price from $7000-$9000.
Will try to get specific model numbers to you later.
Here are the first seven models in Consumer Reports' list:
Thermador: T36BB820SS $7400
Bosch Integra 800 Series: B36BT830NS $7500
Thermador: T36BT810NS $8000
Sub-Zero: BI42S $8000
Miele: KF1901Vi $7200
Liebherr: CS2060 $5000
LG: LSSB2791 $8500
The only model that scored quite low was one from Viking. Probably want to avoid that brand.
Unless money is no object,  I would remove both units, contact a local cabinet maker to modify the opening at top with a complementary glass door cabinet, and slip in separate "built in style" fridge and freezer units with good ratings.  As much as I love the look of built ins,  they have so many issues.  My ex and I designed the kitchen in our Brooklyn condo and put in a Sub zero built in.  Although it looked great,  there was always something wrong with it, and to be honest,  it didn't hold as much as you would think it should.
Thanks for the info
Will start looking at the above units for her consideration. She considered redoing the kitchen but feels it would be cheaper to spend 14 to 20 thousand to replace the units. No, money is not an object to her. She just wants to have units that function on their own for more than a month or 2. She designed the kitchen when they had the house built 10 years ago. I questioned her about the design with the double ovens between the 2. Hopefully there are walls around the units and not open to the ovens in the corner. Thanks for all your info.
Jon
So far, our counter depth French door bottom freezer Kitchen Aid has been fine after about 1.5 years. I wonder if they have something similar in a size she can use. The general model got great consumer reviews.
Isn't that a shame that I'm crossing my fingers thinking I'm jinxing ours by saying that after that short amount of time!
Ours replaced a Sub Zero built in service problem model. I just used the left over space above to build a shelf.
Chuck
The freezer has died. The repair man was out again and replaced the temp selector on the fridge. While there the freezer was making a strange noise. He touched the compressor and that was it. It died. So with info in hand doing on line research for the new purchase.
Jon
