loud roaring noise
benniebena
Oct 2, 2011
I have an Amana Distinctions washer that is about 10 years old, when in spin cycle makes a loud roaring noise, sounds like maybe a bearing, but I am not sure where to start looking, or how to look for cause, any suggestions would really help. Thanks benniebena.
Most Likely Tis The Bearings
With the drum empty stick your hand inside and turn the tub. If you hear any rattles or strange noises then that is another sign. Also test the tub by pushing up, down and side to side gently. If there is any more than normal play then you have another sign.
You can also pull the washer out from the wall,take off the back cover and look around the bearing area. If you see any sort of rusting or traces of leaking fluids....
Depending upon the design of your washer replacing the bearings can either be an easy job or one with so much effort/cost tis not worth really bothering with.
What you can do is go to any good spare parts site such as Sears Parts.com and key in your model number. You want to find out if the bearings, seals and assembly are sold and how they all fit together.
Does the pitch of the roar follow the speed of the drum? I had a VW bus that did that. The front bearings had very small pits on the races. It doesn't take much. And once they are roaring, can't say how much longer they will last.
NOISEY AMANA WASHER
If it roars in the spin cycle with nothing in it the bearings have gotten water in them. Don't bother moving the washer away from the wall as the back panel does not come off until you are ready to haul it to the curb. This is not an easy or inexpensive job, so it is new washer time. If you have liked this machine go get a new SQ top loading machine as it is about the same design except that SQ has a much better seal design so the new machine probably will not have this problem for more than 20 years.
wp design direct drive if its not leacking water run it till it quits sorry but the screws its put together with will be crowded a next to be inpossable to remove
