mattl
Got an old Magic Chef W20HN2 that has seen better days. Only the delicate cycle works, on the others the unit won't agitate. Timer moves and it drains and spins if I recall correctly. It really has a huge tub, looks like it could hold a lot. Isn't this a Norge based unit?
Only thing that comes to mind is a bad motor, with the high speed winding burned out. Odds are it's not the timer, unless the contacts for regular speed are burned. Have not torn into it, I guess it could even be a loose connection. Any suggestions?
Going to trash it if it's not an easy fix, otherwise I'll donate it to a charity.
