brisnat81
Hi All,
I've got a Neptune 7550 that has all of a sudden started displaying Speed Sense Error when you start the cycle. Sometimes the door will unlock, other times it stays locked and you have to use the release to get the door opened.
When you go into the Diags, it is reporting the following
Diag 6 - Locked Rotor
Help 41 - Failed to Verify Tach
I'm assuming that the Help 41 is related to the fact that the drum isn't turning and that this is the same reason that the door wont open sometimes.
With the Diag 6 code, the Drum and motor seem to rotate freely, so I'm not sure what's wrong. Can anyone advise on what else can cause the Diag 6 error?
Thankyou in advance for your help
Cheers
Nathan
Cheers
Nathan
