funktionalart
Curious if any of you have taken on the project of piecing together replacement door seal gaskets yourself (vs. buying ready-made ones)?
I have a SubZero side by side I'm going to part out which has VERY nice newish door gaskets--as there is ample length to work with, I'd like to remove them and use various lengths to craft a new freezer door gasket on a 32" wide bottom freezer door. They SubZero ones are an exact match to the white colour and thickness the old freezer requires.
My question, before I even start attempting this: how to weld/seal the four 45 degree corner cuts I will have. I'm sure this is done properly with some sort of heat sealing machine, but as I haven't got one of those, is there a liquid vinyl or other compatible material I could buy and use? I figured surely in this crowd one of you has done this before!
Many thanks~Allen
Many thanks~Allen
