Mastercut Collection?
Gas,fumes,NOISE,HASSLEt,hat is why I went to cordless electrics-and they have more TORQUE than gas mowers.But the runtime is much less.Now-if someone builds a cordless AFFORDABLE rider-I would be interested.Bring back the Elect-Trac?
Sunbeam Model 7019A burning out extension cords
Hello, I'm looking for some guidance from someone who has restored or repaired a mower like the yellow Mastercut at the top of this thread. Mine is very similar, 12 amp, but says Sunbeam, not Mastercut across the front. I picked it up before the garbage truck did & I've used it for about 10 years.
I use it 3-4 times per year to cut the crabgrass at a vacation home.
Only problem I've had is keeping the extension cord plugged in. About a month ago, the female end of the heavy duty 50 foot extension cord that I've used for 10 years started smoking where it plugs into the mower. Used a different extension cord to finish mowing and put a replacement end on the cord.
Trying to eliminate the problem of the plug falling out, I got the bright idea to make a short extension cord that would stay attached to the mower in case the taking it on and off was part of the problem.
Did that and the next time I was mowing, everything was working fine so in addition to mowing I was mulching lots of leaves for about an hour when my new little extension cord started smoking at the female end, where it attached to the mower. This time in addition to killing my little extension (which might not have been heavy duty enough), the male "plug" on the mower is also burnt.
Am I correct that the male "plug" in the handle switch are actually called leads that can be replaced?
Does anyone know what might be causing this problem? I guess the mower is at least 30 years old but I can't find any info about it online. Handle/Power switch is similar to photo below.
Many, many thanks for any help or information!
Jfv1103
Jo,
Sorry for being five years late, but if you still have this machine (the Sunbeam 7019A), it should be known that you are supposed to at least have a 100-foot, 14-gauge extension cord. That is why your 50-foot extension was smoking on you the last time you used this.
~Ben
Most likely the cause of the cord overheating is due to a not-thick-enough wire gauge.
Another possibility is a problem with the connectors on the extension cord where it plugs into the mower. They may not have a good enough connection/contact. One remedy could be to polish the handle prongs a bit so they conduct better. Another possibility is the handle connection has deteriorated to the point where it needs to be replaced.
Offhand, I'd say a shorter cord could carry more amps better than a longer cord of the same wire gauge.
I'd probably take it all to a lawn mower shop and ask them to diasgnose the problem.
