Maypool Direct Drive Washer Spin Noise... Any Ideas?
Rattling vibrating Noise On A DD washer
Top agitator shaft bearing is slightly worn, you could take the transmission out and grease the top bearing or a more permeant fix would require a new brake and spin tube.
It will probably work for a long time without doing anything if you just want to keep using the washer.
John L.
