Maytag 142 rollers/srpings
First, double check to see if you have a sliding motor carriage. I believe all 142's still had the earlier swing mount clutching motor.
In any case, ALL 2 belt Maytags use the same 205000 spring/glide kit. Earlier machines used the round "Lifesaver" wheels, which was updated to square glides in the 90's. Both designs are compatible with each other.
