Maytag 2-4012
Mr-elmo
Oct 20, 2004
5
I Have a lot of the good quality depenable Maytag top loaders,unlike the wide mouth and newer models. Maytag has discontinued the original 2-4012 seal kit with the A4298 seal, and they only have available the crappy 2224012, which will not work more than 30 days on the old style transmission. Gemline or Westward had a aftermarket seal kit, but i can't locate a vendor-- help!!
For what its worth,when I was rebuilding Maytags for resale, I never bought a new stem and seal kit (I'm too cheap). I was always able to stop one from leaking either by using a used accordion seal and cleaning up the stem piece and using a new 0A4298 on top or sometimes I would lap the sealing surface on the stem with fine emery cloth to seat the new (old) Seal. It is much more work than replacing the stem and seal kit new and it may take a couple tries to get it to seal but It might be an alternative in a pinch. It worked for me many times.
One distributor I use, CE Sundberg, usually gives a Supco part when I ask for a Gemline number. Apparently Supco has many of the aftermarket parts that used to be sold by Gemline. Good news though that Gemline is back in business.
Here's A link to Supco. The stem kit is available from them as well as a stem boot seal separately. I don't think you can buy from them directly. You will have to find a distributor such as CE Sundberg.
http://www.supco.com/
