Thanks to those who have contributed to this wonderful website!
You've inspired me to save a pair of old Maytags (a806 de808) from the landfill.
In the spirit of giving back, here is what I learned from my restoration (that I haven't seen on this site).
For the dryer:
Dryer-sheet residue came off with Meguiar's rubbing compound. This was more challenging than I thought it would be.
For the washer:
Removed the agitator with nylon straps and a metal bar lever braced with towels and a wood plank. At first I thought I could achieve success with brute strength... go ahead and laugh.
Tub bleach-tube was replaced with newer poly-tube (much more flexible/chemical resistant).
Replaced old broken tub backflow preventer with a new one (designed for a hot-tub), attached below the bleach dispenser.
Disassembled break package, cleaned with solvent (70% ethanol), and reassembled with red gasket sealer.
All the rest you've heard before...
Bypassed the injector valve with PVC and zip ties
Used modern ATF fluid for the transmission
POR-15 for the base
Silicone based lube for the switches
New rubber all around...
They have both been running like champs for 6 months.
I've included a few images that hopefully add to this post.
Thanks again.
Let's save some more machines!
P.S. I know how lucky I was to find these right away...
For the dryer:
For the washer:
POR-15 for the base
Thanks again.
