Maytag 806 new acquisition
casciomichael
Jan 4, 2021
24
Rutherford
Hello everyone,
I would like to introduce myself. My name is Mike and I am a collector of many things. Vintage appliances has become one of my new hobbies. To complete my cross section of vintage appliances, I was looking for a vintage washer and dryer. I settled on Maytag for their decent looks, durability and availability of parts. I figured a pair of 806’s would fit the bill, my only dilemma is that a gas dryer was necessary. Vintage gas dryers are very hard to come by on the east coast, it appears that most people used electric in my area. On shoppers square an aw member oldskool was selling off some of his collection. He had several pairs of 806’s with dg808 big load dryers. We struck a deal and made arrangements to have them shipped. These machines were DD’d by oldskool for several years but have been in storage for the last 5-6 yrs. I figured some things would need to be done to put them in top shape but not a total restoration. I cleaned the dryer thoroughly, it was mosty clogged with lint and oiled the motor and tensioner. The performance of the dryer is very impressive.
The washer on the other hand has been giving me fits, it was rumbling horribly on the platform that my former washer sat on. I should have listened to my fellow aw friends who said get it off the wood at square one but I was not convinced! I ended up leveling the chassis and them attemped to adjust the balancing springs to no avail. Then I cleaned and relubed the damper pads which I thought helped a bit. The problem was still there. Also I corrected a pesky leak a the injector and the tub seal was leaking in the first few loads but then stopped. After a couple of lost days, I moved the machine to a concrete surface where I could test spin out. Much to my surprise, it didnt rumble! I said to my self, “they were right all along”.
After this discovery I balanced rhe springs as per the service manual. Also I managed to pull the agitator off to inspect the spanner nut and seal. It took two moving straps, boiling hot water and a 5 foot long 2x4 to get that thing off!!! Things didnt look too bad under there, i cleaned up the rust and put some grease on the shaft so next time will be easier. After all was said and done I can hear a clatter faintly when agitating and louder while the machine is spinning up. After it reaches full spin, it goes away. It is coming from under the machine by the pulley area. I pulled the pulley and inspected the thrust bearing, it seems like it is a bit loose to me but its a ball bearing and its not in its race with pressure. I cleaned and repacked it but the noise persists. After seeing many of Eugenes videos on You Tube I saw he was putting a dynamat like material inside the machine. I got some On Amazon and gave it a similar treatment. It does really help!
I have a link to the video and was wondering if anybody has heard it before and can confirm or deny my suspicions. Also here are some pictures of my new machines, looking forward to hearing from you all!
Michael
Motor carriage
Yes the motor carriage looks a little crusty, the springs have good tension and it agitates and comes up to spin pretty quickly. I squirted some oil on the rollers for good measure but it was moving freely. I have run the machine with the cover on and off and this noise is coming from under the machine. I just dont know if this is something I should be worried about or not.
Help?
I was hoping to see if anyone knew what this noise is. Link posted to the video here.
On a separate note, I got new maytag rubber feet in the mail today. One of mine was disintegrated. And the others were not too pretty.
Drain Pump Belt
Check to make sure that the tension on the drain pump belt is no too loose. Just a thought. Have had tons of these Maytag's and never a sound like you are experiencing.
It does sound like the drain pump belt is slapping either the underside of the machine or the "belt guard" attached to the front panel.
Just a thought.
If I were you, I'd do a complete overhaul of such a nice machine. Yeah, it will take some time and elbow grease, but worth it!
--Steven
Drain Pump Belt?
I just had the machine tilted up and cleaned the belts and pulleys. The trans pulley has a definite wobble to it. The screw is tight. I had the pulley out to inspect the thrust bearing and thought the bearing seems kind of loose. How is that pulley supposed to feel? It does have the star washer under the phillips screw.
I have heard this noise with the front cover/belt guard on or off the machine.
The pump pulley feels tight.
Whoops, I read that wrong. There should be no play in the motor pulley. Remove the belts and twist the 2 motor pulleys in opposite directions. If they move, it's time for a new one.
Just a bit of clarification...
Hey Guys,
I have a set of 806's that I got last year. I am still learning a lot, so I am not the expert to address Mike's problem.
However, the wobble he is referring to is with the "Large" Tub pulley at the center shaft of the machine.
He is asking if anyone has encountered this, or an issue with the thrust bearing it rides against.
I just thought I'd clarify his question, as I would like to know the answer/ info on this issue, since I am going over the belts/pulleys on my A806. Thanks guys.
Louis
When you put the trans pulley back on, did you set the stop lug with the specified adjustment, per the service manual? Without the preloaded tension on the pulley I could see how it may wobble like that when at the bottom of the helix.
Ben
drive pulley wobbling
I checked the pulley on my A712, it has some play in the pulley as well but doesn't knock like yours.
Using your foot or something try putting outward pressure on the the motor slide assembly and listen if the sound changes any.
BTW- I have a very early A806 with the tub light that needs a good home if you're interested.
It's disassemble but all cleaned and ready to go back together.
Locking lug
I am going to recheck the locking lug. I believe it was on wrong when I pulled the pulley and I misunderstood the adjustment. To clarify, I need to turn the pulley clockwise until the tub starts to turn, then position the lug about 1/4-3/8 away from the pulley?
