From the closeup shot of the consoles, it looks as if the washer has 3 speed options. With 3 temps and 4 load size options, I am guessing it is an A407. I wish I could make out the cycle selections to be sure. The 407 had the wash cycle, and a timed soak with spinout at the end. I believe there was an additional cycle marked "Soak Only" which probably provided a few minutes of agitation, and just stopped, leaving the user to manually set the washer to spin in order to drain it. It is a nice set which hopefully will find a good home.
Have a good one,
James
