Maytag A106 Project
79maytaga106
Active member
Jan 17, 2019
25
Texas
Hello everybody. Long time visitor, and finally opened an account!
I am in the process of acquiring all the parts to refurbish my Maytag A106, built in 1979. I have looked up several threads regarding this style of washer, and feel confidant I can perform needed repairs. A spanner wrench, and brake tool are in my toolbox. Any other specialty tools I should consider?
I plan on going all the way with this machine, because of not being impressed with the longevity, and quality of what's currently on the market. The tub seal, bearing and all looks straightforward. The transmission looks tedious, but I'm up for the challenge. I have very little oil staining on the inside of the cabinet, but the lower seal is beginning to leak. I would like to address this before NLA parts are damaged.
The machine currently works just fine with a minor knocking during the first few seconds of agitation. No other strange noises. The only part I've not been able to locate is part 210183 groove pin. Does anyone have a source, or know the size specs for this particular groove pin. Also what is a good way to drive it out, and install a new one? I appreciate advice, and tips from the Maytag experts on here!
What I've done so far is pull the agitator, clean, and inspect the parts under it. The agitator actually popped of easily after 5 minutes of having a hair dryer blowing down it. I also pulled the front cover to inspect the inner workings, and didn't see evidence of any water leaks. This a more of an attempt to preserve what I've got, before it's too late, because we all know I can't just run down to the appliance store and pick up a brand new A106!
Below is a link to how this washing machine looks, ans is currently functioning.
Very nice!  I look forward to seeing the finished work.  It already looks to be in good shape but doing those basic service items will keep it going for years to come.
Thank you! I have a lot of parts on order, and will get started once I get everything in. Hopefully I can locate the groove pin soon. I added a picture of my parts collection so far.
APCO parts has a few of the groove pins in stock. However, unless there is a need to disassemble the agitator shaft from the top half of the transmission, I’d recommend leaving it be. Typically if everything looks good I flush out the bearing through the lubrication passage and lubricate the upper case bearing with some zoom spout oil. If you do decide to take it apart I’d recommend replacing the spring washer with a new one. 15902 or Y015902.
The knock might be from a lack of oil and play in the spring washer. Otherwise, everything looks CLEAN.
Ben
https://www.appliancepartscompany.com/product/11207113
Thanks for the leads on the p/n's, Ben! I'll just go ahead, and order them before they become NLA. It's been knocking like that for years, and hasn't gotten any worse. I really want to crack it open to at least see what the oil looks like after 40 years. I have a bottle of 56080 on the way, and a new gasket. Do you know what the torque specs are for the perimeter bolts?
I think I've reused the drive pin.
Although, as mentioned it's not really critical to remove the agitator shaft if in good shape with no play.
Flushing and making sure to get trans oil up there will suffice.
This seems to be more of preventive maintenance job as the machine looks to be good condition over all. The lower trans oil seal o-ring along with the mounting stem and damper pads are items that usually take priority. You may even be able to reuse the tub bearing and just replace the sleeve, the older design was better anyway with a wicking that could be re-lubed.
using the gold panel by 1979?
Louie, I remember the 106 models still used the blue panel in 1979.  Anyone have a near-the-end brochure from Maytag showing this for sure?
**IF** you remove the groove pin on the agitator shaft, you have to be extremely careful when you do so.
On later years of these transmissions, that gear is a sintered metal part, so it is not as durable as a solid machined gear would be. One wrong strike with the punch, or not supporting the gear properly, and you could easily crack or break the gear.
In the case of our A308, removal of this pin was necessary as the agitator shaft was binding in the case. We made a sacrificial wooden support to hold the gear (and transmission half) while removing the pin, so that the fixture would yield before the gear. It worked, but it took considerable force and our groove pin came out in pieces.
With the binding shaft, we didn't have the option to leave ours together. Having taken it apart, I would agree with the others to leave yours together if it feels OK- It's just not worth the risk!
Ok thanks everybody for the suggestions! Very much appreciated! I'll go ahead and plan on leaving the agitator shaft alone, and just lube it as described above. I won't know the condition for sure until it's opened up for inspection. I located and ordered a NOS agitator shaft, pinion gear, and other related parts to have on hand, just in case. As I was looking at various parts sites, I noticed many parts were discontinued last year, so I'd rather be safe than sorry.
I have a damper pad kit, and adhesive on the way as well. Yes this is totally a preventive maintenance procedure. After 40 years of excellent service, I think it's time, and really do not want to replace this washer, even though it is BOL. It's been family owned since new. I just love the simplicity of it, not many bells and whistles, less to break. Just gets the job done, very well, day in, day out, and that's all I want.
I will continue to study previous threads on the subject, while waiting for all parts to arrive. This site is a goldmine of information! I've also downloaded the service manual to study up on, and understand the service procedures. One thing I'm confused about is in the service literature it states to lube the carbon seal on the boot with a thin layer of transmission fluid. On the new seal I got, it states to make sure the seals are clean and dry. How do I proceed with that?
Does anyone know what color that blue is on the control panel? I'd like to repaint that section the same color, or at least get close.
Plugging the data into Appliance411 dates manufacture during September of 1979!
I recall seeing some paperwork many years ago stating it was delivered to my Aunt, and Uncle in May of 1980.
Ebay had two, yesterday. I bought one, and then shortly after someone else bought the other. Thanks for the paint color thread, I'll get a can!
Service manual states "transmission oil", i.e. Maytag trans oil.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?22830
Since the new seal is a revised design you may want to follow the included instructions, but I'm not 100% sure on that.
Last one I did with the new lip seal design was installed clean and dry, so far no leaks.
On the other hand, is it safe to reuse the old design mounting stem with a new agitator seal and boot, since the newer triple lip seals are known to fail more often??
Service manual says yes if no signs of water seepage.
The paint recommended by LowEfficiency (Dave) is a perfect choice!  I used it on my A407 rebuild and it worked out perfectly.  I also painted the upper portion of the console with Whirlpool Appliance Paint.  The worst part is masking everything off!
Thanks for the clarification good-shepherd!
Dang, eurekastar that control panel really pops! Can't wait to get mine to that condition.
If all goes well I plan to start the project in the next week or two.
I still say they should have matched the control panel's lower color to the actual color of the machine....
the blue compliments a white body, as it sort of has a bluish/gray hint to it...
I think if I had any other color than white, I would change that to match, just for a different look....especially on a matched set....
That was my parents on the second one!! NOS agitator shafts are extremely hard to come by, so you (and us) got very lucky that those showed up! I'd been keeping an eye out, but somehow missed that one, so thanks for posting that you found one. It made me do another search, and that's when I found the auction.
Glad the paint thread was useful. I saved the link a long time ago, back when I thought I would need it. Now, however, I somehow ended up with two "sunglow" gold panel machines. So if a blue machine came my way, I'd have a dilemma on which one to repaint to match!
That's great!
Since you've done it, perhaps you can answer a question I've had... Would you consider the Avignon Blue Metallic to be a good match for the original Maytag color? Or is it just "close" and a pleasant color? That's something I've had a hard time discerning from other posts. It wouldn't be a problem if you repainted two machines, but I haven't seen a side-by-side of original vs repainted...
That's an interesting thought.
Some of the color combinations Maytag produced worked really well, but (in my opinion) not all of them.
For example, the Almond machines look really sharp with the sunglow gold panels. The late-production unshaded Harvest Wheat and Fresh Avocado machines also look good with the gold panels, in a much more subtle and refined way than the earlier shaded machines with the blue panels...
I'd gladly trade any of those for a turquoise/blue combo though. And there are of course combinations never before seen, such as a blue panel on an almond machine, or a gold panel on a turquoise machine.
@ LowEfficeincy
The color is a little deeper, but very nice.  It definitely works.  I wonder if paint like that will fade over time and that's why the new paint looks richer.
Just a quick update! Parts are arriving almost daily. I found the spray paint at O'Reilly, too. I am also going with the older style seal that uses the spring clip, and washer to hold in the agitator seal. Does it look like I have everything covered? Any other lube/grease I should purchase? I sure appreciate all the advice!
Transmission gasket, Zoom spout Tubine oil.
Too bad you can't find a more upscale Maytag to refurb, seems like such a waste to put all those nice parts in a lowly BOL unit.
A106 Ready For A Rebuild
It looks like you have most of what you need, to use the older style agitator shaft seal you have to use the older style mounting stem and seal kit, the newer style triple lip seal is a superior seal especially with a new agitator shaft, but either will work quite well.
Rebuilding a basic A106 makes perfect sense, the smaller tub MT washers have superior turn over and rinsing, it all the washer you would ever really need.
Keep us posted
I've been through similar thought processes, but in the end, other than your time, there's really not a lot of downsides since so many parts can be transferred over, or your restored machine could be used as the basis for an upgrade down the line (control panel swap, 2-speed conversion, etc).
At worst, you've fixed up a nice machine that could either be sold to finance the purchase of a higher-spec model, or retained as a standby backup machine.
good-shepherd, got them both, just forgot to include in the picture! Actually the zoom spout is in the tool bag sitting in the chair to the right of the tables. The gasket is between two large books, to keep it flat.
As far as why would I refurbish a BOL Maytag A106? I may not have mentioned this before, but it's because my Aunt bought this machine brand new, and was so proud of it. They didn't have a lot of money, but they got a Maytag! It has served our family almost flawlessly for 40 years now, with minimal maintenance, no breakdowns major enough to be put out of service! It's purely for sentimental reasons, and is cool to have the actual machine I grew up around.
I guess the only upgrade I'd like to do with this one, is get a control panel face with bright trim. I think it would make it look way nicer.
Sure, more features would be cool, but this one gets the job done, day in, day out!
I spent this morning replacing the rollers and springs kit on the motor, and made sure to use the two pouches of included polylube. The pump belt needed to be readjusted as the gap, when squeezed together was more than 1/4 inch, it's spot on now. I immediately noticed it runs quieter after this service. The slight knocking upon agitation start is almost completely gone!
While it was tilted back, I could see the damper pads are still in place, but are on the list to be replaced. Just out of curiosity, I spun the pulley to see how tight the agitator shaft is, and I was able to spin it easily with one finger.
I figure since the original seal is still good after 40 years, it must be pretty darn good!
Thanks everybody for all the comments, and feedback!
