Thank you,70series! I'm glad you enjoy my videos, I appreciate the views!
I've gotten a lot knocked out on this restore, but still a good bit to do.
good-shepherd, amazingly that sleeve came right off. No corrosion whatsoever! I couldn't believe it. That is the adhesive I had purchased, 055978 but it had already set up to the point it was unusable. I went ahead and used the high-temp adhesive I used for the dryer felt seal, and seems to have made a great bond for the damper pads. I let them dry for several hours, and then coated with the included poly-lube tubes.
I have had an unfortunate casualty, the oil cap for the main drive pulley. P/N 211038
It was very cracked up upon removal, and I didn't have high hopes of ever getting it back on. I was thinking it used to be more flexible, years ago, but it certainly isn't any longer. If someone has a lead, or an extra to sell, I'd sure appreciate it!
Here are a few pictures of my progress. I did make sure the lug was set correctly, too, in the 1/4-3/8 range! I started getting tired, so I called it a day.
