dustin92
I've noticed since I got my near-mint A207 (1974 model) that it's always seemed to take a second to start agitation or spin, longer than the 1980 A308 that it replaced. Today I had a load running and I needed to use the microwave to heat up leftovers for lunch (yes, our microwave is in the laundry room, kitchen doesn't have any good place for one!) We have never had any issues in the past, as long as it's only the washer *or* dryer running while the microwave is being used. Only the washer and microwave running, washer finished agitation and paused, then I heard an odd hum from the laundry room- I started running for the laundry room and before I got there, all went silent (microwave, washer, tv in the living room) a fuse had blown. Lifted the lid on the washer, went and replaced the fuse. I'm assuming the centrifugal switch didn't kick out, and the extra current draw popped the fuse. All seems fine now, no burning smells after it happened, so I'm assuming the washer is fine. Have run several loads today, and it's working fine, but still starting a bit slowly. Is this something to be concerned about or just business as usual? Just worried I could have trouble around the corner.
