Maytag A208 Timer
rookie1
Member
Jun 14, 2016
8
Indiana
Hi All, I have a big problem. My brother changed the timer on my Mothers(stay with me) Maytag A208 washer. I believe he mis connected a wire because it is not working. I have scoured the interenet to find a color coded schematic to no avail. Maytag was no help either. Where can I find one of these?
Maybe this picture will help.  You can try using the "super searchalator" at top right of the index page. Type in "maytag a208 timer" to pull up archived threads that may provide useful information.
Also, I've provided a link to a service manual download that may help.
http://www.automatice.org/cgi-bin/index.cgi?showdoc~67~Maytag~AW
I'll keep you posted(no pun intended). I should be able to get over there Thursday evening, is the washer front just held on by clips and lifts off or are there some hidden screws I need to look for?
Maytag wiring-
Maytag wires have numbers printed on them near the terminal end that should match with the numbers on the timer.
The front panel is held on with 2 Phillips screws about 3 inches from the bottom.
I'm not sure why you'd need to take the entire front panel off of the washer's cabinet, but as Jeff stated, they're up front at the bottom.  You can't see them unless you get down there and look, and you'll need a fairly short screwdriver.  The panel swings out and lifts off once the screws are out.
Thanks for the info on the numbered wires and front panel removal! I'm going over there tonight, I'm hoping the wires are in good enough shape to read the numbers as that should solve my problem. Failing that I'll take the front panel off and have a look for the diagram.
I can't thank you guys enough for all the help!
new problem
1st and foremost Thanks again for the timer help!
Now I have a new problem with the machine. The washer and timer work fine on Hot/warm setting, but when they use the hot/cold or warm/cold cycle the washer fills fine then washes/agitates and gets and gets to the rinse/spin cycle and just stops. If I manually advance the timer it completes the cycle normally. Is there a cold water valve solenoid or something I should be investigating? At this point I'm only out around $45 for the timer and I'd like to keep this machine going, My mother is 90 years old and despises change in addition to the fact its a strong machine.
Thanks!
Considering that the timer and the water temperature selectors are two separate systems, it seems odd that the warm or cold wash/rinse settings would have any effect on the timer's function.
If you're getting warm and cold water into the tub by manually advancing the timer, the cold valve solenoid must be OK.
This is beyond my scope and will require advice from the experts.
Jeff, I'm guessing that at her age, Brian's mom knows better than to run a cold water wash, but I'll be interested in finding out if there's any connection between temperature selections and timer dead zones.  Seems to me that there shouldn't be.
Thanks guys, I'm going over there today to see if it will fill on cold. A new water inlet valve is only 22 bucks. Where is it located? I'm thinking it's behind the hose input?
It does not fill on cold, so I think the inlet valve is probably the right direction. I'll get it changed after it comes in and keep my fingers crossed.
Finally got over to my Moms to change the inlet valve. Installation was a breeze and I changed the hoses also(I had a spare set). Machine now runs like it did 25 years ago, more importantly, Mom is totally happy.
Thanks again all.
