I just picked up a Maytag A606 set in Avocado green for $30! The washer is in good shape, and the dryer is also in good shape, but the the push button assembly seems to be gummed up, but everything else appears to be fine other than needing to be cleaned. The dryer does have a pilot light on it, but there surprisingly isn’t much rust, and the dryer doesn’t appear to be high mileage, and the felt seal the helps direct the air through the burner is in okay shape, but otherwise is in decent shape. The drum spins freely, and the tensioner pulley had some resistance but is in good shape
