my new and much more simpler coffee maker
daveamkrayoguy
Silver Member
Dec 8, 2010
5,791
Oak Park, MI
Well, usually I fill the water up to 5 cups, but decided to make 8 cups just to see the water remaining at that 5 while the wanted 8 was at an espresso-sized quantity so I decided it was time to ditch my old machine…
And figured I could do without a timer and automatic brewing as well as a clock I always needed to set and reset though that was convenient to view…
The buttons could sometimes be accidentally stated or one time wouldn’t push in to turn on or the plug had to be pulled to turn off…
So I got a cheap toastmaster unit usually seen in motels with a lighted and sturdy toggle on and off switch on the side as well as the water spout attached to the lid and saved my reusable filter from the old appliance…
    1.5 MB
    1.3 MB
    1.9 MB
    1.5 MB
    1.9 MB
    1.7 MB
    1.9 MB
    2.2 MB
    2.5 MB
    2.5 MB
Sometimes simple is best....and longer lasting. Cheers!
Thank you and might I say I’m getting better coffee than my stovetop coffee making and I can even drink all of it without having to reheat molten leaden coffee later…
This coffee maker lets me tailor it he amount I can drink not make me fill the whole vessel and none of that grit at the bottom either…
I can even still use the big metal pot for additional heating it up as well…
Any heat generating appliance should be UNPLUGED when not in use. Found that out when my old Proctor Silex coffeemaker was recalled due to chances of fire. My next door neighbor is a retired fire chief and he said you would not believe the amount of home fires any heat generating device can cause, including hair dryers, curling irons and toasters. Better to unplug and be safe.
My daily driver coffee maker is a KitchenAid siphon/vacuum type. I prepare everything the night
before, and just flick the switch when I get up in the morning. Sales and support for these from KitchenAid is no longer available.😥 Its process of mixing all of the water with all of the coffee grounds and then aerating it, makes my favorite, great-tasting coffee.
