Maytag A608 era
Maytag A608 partial restore
Well, when motor carriage parts arrived, I dug further into my A608-----wire brushed inside the cabinet, vacuumed, wiped down, dried overnight, then Rustoleum inside and out primer then 2 topcoats, but I put it all together again before I remembered camera, sorry no interior shots.
I continued washing clothes during some portions of this weekend project, seems to be 2 drops of water from the fill/water gap doodad every other load or so, I don't think that's the total breakdown of that cheapie plastic item I've heard tell of, so I just closed the top up and will ignore temporarily.
Anyhows, not at all a complete restore job, but very spruced up and no rust inside or out, new motor carriage rollers/springs/lube, 2 new tinnerman snaps for front, check up this thread for rusty before pics, here's 2 after painting. I still have half a can left, my guy has better eyes for color and will advise another coat or not.
There's tons better restoreres out there, I'm learning the task and sticking within a budget.
Great machines. Under the hood they look the same for a long time, 8,10, and 12 series. There is a nice 12 series pair on Craigslist local here for 100 bux. I wish I had a huge barn just to set up a collection.
I had a 712 pair from 1985-2001 and wish I would have kept them. Just one minor no cost repair in 17 years.
Ive always wanted the center dial one just for nostalgia with a light up console.
Hello - My beloved A608 went out and the Sears Home Repair technician said the transmission and timer had to be replaced. Transmission would cost $726+tax = $800 + $450 installation + $200 more for gearcase and some other part. Subtotal $1,450 without the timer, which he said was no longer available.
Found the timer, with knob, on eBay for $113, which should be delivered next week, and watched a video on how easy it would be to install myself. Trying to find a transmission for less than $800. No success so far.
Just found a working A608 on Craigslist 500 miles away for $100. Trucking cost would be around $200.
Question: Does anyone here think I should get the used A608, or would you instead recommend this new metal Maytag produced in Maytag's Commercial Factory in Ohio?
Kirk Rivas, an appliance guy in Austin Texas, has uploaded SEVENTEEN videos showing the new Maytag MVWP575GW in action through entire cycles with the lid open. Looks like a great machine. Here is one of his videos:
Big box stores don't carry the new model. I've already ordered the new model from Designer Appliances, a dealer with 3 New Jersey showrooms and the best online price I found - $719 plus $119 shipping = $838. No tax. List is $899. Will take about 10 days to get to California.
But what about the used A608 500 miles away? Should I forget about it or get it and store in "just in case?" I am really, really fond of that machine. The only thing I like better about the new model is that it has a 17" basket opening rather than the 13 1/2" opening on the A608.
Thank you for any thoughts you might have. Love all the valuable advice and insights I've found from you experts here.
P.S. Akronman, the original poster, asked what year his A608 was made. His serial number ended in CX. Found a Maytag chart indicating C stood for 1978 and X stood for December, so December, 1978. Mine ended in EG = April, 1980.
I'm no expert, but I can tell you with assurance that an A608 would have far more cycle flexibility than the new Maytag. You actually get to select the water level on the old A608, the new MT has only two options, Full Fill and Automatic load Sense. If you have the space to store the new A608, I say get it, you have nothing to lose.
As something final to say, I have my doubts about what the Sears Technician said, in today's world, sadly, many service men just make up a bunch of rubbish just to get out of servicing an older machine.
What is exactly wrong with the transmission? If it is just leaking a little oil, you could probably get a few more years out of it.
Thanks for the reply! I'm not sure what, if anything, is wrong with the transmission. Another repairman told me he found it suspicious that two parts would go out at the same time.
When the timer arrives, I'll install it and see if the washer works. If not, then there is probably something wrong with the transmission.
The young Sears repairman said the washer was older that he was. I didn't have a lot of confidence in him, but he was able to consult by phone with someone more expert than he is.
Would you still recommend buying the A608 I found on Craigslist?
<blockquote>DianaM:  Transmission would cost $726+tax = $800 + $450 installation + $200 more for gearcase and some other part.</blockquote> The transmission is sometimes referred to as the gearcase ... there's nothing else "gear"-related on a 608 other than the transmission, so seems a mystery what your servicer meant regards to the two separate items.  Maybe the tub brake assembly? (which may not be needed).
Your 608 has what's called a "pitman"-style transmission.  New replacements are NLA (but it can possibly be repaired depending on what's wrong).  The substitution is the newer "orbital"-style transmission which has a shorter/faster agitation stroke.  I find $238 at one online source.
If the "trans" is the problem, any helical drive, tall tub trans from a Maytag Dependable Care washer up to about the late 80's 12 series will swap right in.
No need to find another A608 for donor parts.
However, servicing the trans involves quite bit of work. Good news is you get to replace the stem/boot seal and tub bearing, two items that will wear out sooner or later anyway and may well be part of the problem.
Here is a nice A610 (or 710), could be used as is or for parts.
https://losangeles.craigslist.org/sgv/app/d/maytag-washer-and-dryer-white/6446746874.html
Very interesting A610 for sale, and at a great price! Not too far away, either. Thanks for the find.
Tried to install the timer I got on eBay, with knob that looks identical to the A608, but that eBay part is 2-4476-1, whereas mine is 2-04476-3. They're not alike at all. Looks like the 2-4476-1 is for model A606.
Would that even work in a model A608?
The first 2 photos below are of the used eBay timer 2-4476-1; the last 4 are of the original installed timer, 2-04476-3.
I'm not sure how to proceed, if at all. The new Maytag Commercial washer is on its way from New Jersey, and there is a working model similar to the A608 still for sale in a neighboring state.
So you already ordered a new washer??
By the way, that CL Maytag is an A710 (one model below the TOL A810), my mistake.
Yes, I actually ordered a Speed Queen January 3, 2018, after being persuaded they were better machines and losing hope my A608 could be repaired.
Then I read the reviews on the 2018 Speed Queen. Oh boy!
Hadn't even heard about the Maytag Commercial MVWP575GW until I saw a comparison of that model with SQ on an obscure laundry company [Lyon Appliance] blog. The author said they were similar but gave the nod to Maytag.
Thank goodness the N.J. appliance dealer hadn't yet put it on a truck and was able to switch the order to the Maytag Commercial residential model. That company's prices btw were below that of other dealers on both models, and they had excellent customer reviews, so it was a no-brainer to buy from them.
Even having to pay $119 for shipping (Speed Queen pays for shipping, Maytag does not), I will be getting a $41 refund for what will almost surely be a better machine.
However, I'm not quite ready to let go of the A608 yet. Forum member SpeedQueen pointed out the Maytag won't have as much flexibility re water level or rinse temperature as the A608. The seller of the working A608[?] has been too busy to check the model and serial number so I haven't had to make a decision whether to buy that or not.
Today I spent 38 minutes on the phone with Sears Home Repair Servies trying to get a simple question answered: How much would they charge to hook up the new washer?
Unbelievably, they switched me to SIX different people, 5 of which could not answer that simple question. You would think I was asking for one of their complex remodeling jobs they touted in the on-hold advertisement - which was better than the 'music' that was so awful I had to hold the receiver away from my ear the rest of the time on hold.
Told them their technician I paid $99 to look at the washer left two belts and a substantial-looking part on my laundry room floor, that it was either theirs or he neglected to put it back in the washer. (He also left his cell phone behind, and I had to run after him to give it to him.) That stymied them but good.
Had to tell the sixth guy 3 different times about the new washer. "Is it new?" he kept asking. Asked if I bought it at Sears, I replied it's a Maytag Commercial residential model Sears doesn't carry. "We don't install commercial washers," was his reply. "Well, it's a commercial model for residential use." Poor guy, he was so confused.
I mentioned I had a coupon for 20% off Sears Home Services total parts and labor, good through 3/31/18. He insisted it was good only if presented at a Sears store. I read him the complete text of the coupon, which said no such thing. It just said to present to a technician and gave the code for the technician to enter. We went around and around on that. Then he claimed the repair had to be prepaid. I told him that wasn't the case when the technician arived for an appointment on 12/29.
I believe the belts and part the technician left on the floor belong on my washer. What would you do?
I'd suggest cutting your losses with Sears, they already gave a questionable diagnoses on the A608.
Installing a washer is not a complicated job; Hot/cold water supply lines and the drain hose.
The hard part is lugging the machines in and out of the house. Any local handymen, plumbers or appliance dealers you could call?
MAYTAG LA710 Washing Machine HELP!!!!
HELP! DOES ANYBODY OUT THERE HAVE A MAYTAG LA710 WASHING MACHINE???
A hole rusted in the wash tub!... And leaked everywhere and is out of commission. I was going to try to replace it BUT apparently they JUST stopped making the replacement part for the wash tub a few years ago for the Maytag LA710 machine!
...So we ended up getting a Maytag Bravos which is COMPLETELY USELESS and chews holes in ALL of my clothing even on the delicate cycles!!! It also does NOT get lint, cat hair, my hair, blanket fuzz off of ANYTHING!!! EVEN IF I WASH IT TWICE! I've TRIED EVERYTHING! It NEEDS to be set on fire and thrown off a very tall cliff onto sharp rocks...
HELP! I NEED MY MAYTAG LA710 WASHING MACHINE BACK!
Does ANYONE have one? Is ANYONE selling one?
Can ANYBODY point me in the right direction?
Please let me know!
I would greatly appreciate it!!
Thank you,
-Erin
Feel free to respond to me via email!
[email protected]
Any large capacity Maytag washer tub (with bleach dispenser if needed) made from 1966 up to the point where they changed to a plastic tub cover (early 90's ?) will interchange with your A710 machine.
